Check if the data notification light is blinking
If no
The machine is in offline mode - Turn ONline
Connector issue - Check printer cable to resolve
Mchine not selected correctly in the application - check printer settings in windows or app
Printer driver issue - Visit the sharp website and download the printer driver and reinstall
If Yes
Check tray setting size
check size of paper
SOURCE: Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
SOURCE: SHARP AR 5320 USB PRINTER PORT DOES NOT WORKING
The usb cannot be switched off in either service of customer modes. have you tried using the parrallel port? Maybe it is a computer issue, wrong drivers perhaps, try a different usb port on your machine
cheers
SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: Sharp AR-M205 is not working with windows vista home edition
1. Uninstall the previous driver
2. Re-install the driver ( do not connect the usb cable at this time )
3. After driver installation, the pc will ask you to connect the usb, do this and it should be OK
