Question about Toshiba Televison & Video
TOSHIBA 52L1350UC intermitent power on/off problem.When it turns ON, I have to leave it ON or disconnect the power cord. I cannot use power button manually or by remote control
5 Suggested Answers
Anonymous
  • 53 Answers
SOURCE: Cinego projector doesn't power up
mmmmmm
Posted on Apr 26, 2008
Anonymous
  • 65 Answers
SOURCE: LG TV REMOTE CONTROL STUCK
i will have to help you here sorry for the inconvenience the chat interface was not working try taking the batterys out of your remote and put them back in
Thank you,
-Rel
Posted on Jun 08, 2008
Anonymous
SOURCE: My Logik L22LID628 tv has
We have had two of these tvs break within 2 days of purchase, in our case both times it seems to be a backlight failure. Did you wall mount your tv? If so when you take the base off it leaves a hole in the casing leaving circuitry visible. I think it's very easy to damage the ciruitry.
Posted on Nov 03, 2008
SOURCE: remote control SENSOR not working
This could be a fault with your remote control. It will need checking by a Television Technician.
You can clean the remote control yourself if you are careful. You will need a spray can of Servisol IPA 170.
  • Carefully split the remote control unit along the seal between the top and bottom of the unit.
  • Carefully notice how you then dismantle the inner components. (I lay the components out in the order I take them out of the unit).
  • In a logical order spray, clean and dry each part.
  • When you have cleaned all the components, reassemble in their reverse order of the way you dismantled the unit.
  • Fit new batteries and test the remote control.
If this fails to solve the problem, you will have to take the remote control to a Television Technician for testing.
If the remote is found to be beyond repair, visit www.semenedis.com who may be able to supply you with a replacement remote control. I trust this information will be of help to you.
Posted on Dec 04, 2008
Anonymous
SOURCE: Toshiba MW20F51 tv won't turn on either manually or with remote
power off all the time
Posted on Mar 12, 2009
How to turn on my Toshiba satellite L305D-S5974, YESTERDAY IT WENT DEAD AND NOW I GOT THE CHARGER BUT ALL I SEE IS AN ORANGE LIGHT BLINKING BUT IT STILL STAY OFF NO FAN,NO SCREEN AT ALL, HELP PLZ
Remove the power cord and remove the battery. Press and hold the power button for 30 seconds... no less... Put the battery back in and plug in the power cord. Try to start it.
If it doesn't work, try again without the battery, just the power cord.
If that doesn't work neither, remove the power cord, and leave it without the battery or power for a couple hours. 3 minimum.
Put everything back and try to start it up again.
Good luck.
Apr 25, 2016 | Toshiba Computers & Internet
Lamp timer reset for toshiba tlpx100
To reset the lamp counter:
  1. Turn power off and unplug the power cord
  2. Simultaneously hold down these three buttons: "ON/STANDBY", "RETURN", "DOWN" (the arrow down symbol)
  3. Plug in the power cord while still holding down the buttons.
    The Projector will emit a series of beeps.
  4. Turn on power using "ON/STANDBY" button and check that "0H" appears on the lamp time in the status display.
  5. Turn off projector using "ON/STANDBY" button
  6. Unplug power cord.
I hope this helps.
Sep 25, 2013 | Toshiba TLPX100 Projector
My Toshiba Satellite refuses to Shutdown or Restart even if I press the power button long.
Hello.
Disconnect the power cord/adapter, flip the laptop and unlock and remove the battery, Reinsert the battery, lock the battery, reconnect the power cord/adapter and power up.
Hope this helps.
Sep 14, 2011 | Toshiba Satellite L645-S4059 14.0"...
My toshiba laptop's screen shut down suddenly while i was playing a game, now i cant turne it on , i dont know what to do?
  • Disconnect all the power supply (battery and power cord) and attachments.
  • Press and hold down the power button for 30 seconds
  • connect with the power cord only
  • restart the computer
It seems the video card is not supporting the game's video requirement
Sep 24, 2010 | HP Pavilion dv6000t Notebook
Replaced ink cartridge still not working
Please remove all the cartridges, clean the Contact points on the cartridges and on the Printer with alcohol/spirit/acetone using a soft brush, don't touch the print heads, you may damage them.
Turn off the printer, disconnect usb cable, power cord and ethernet cable (if any). Leave it Off for few minutes (fix minutes will be enough), also remove/disconnect the power cord from the mains.
Do some cleaning if you can.
Now press the power button several times. Connect the power cord and power on the Machine without anything installed/connected, again leave it On for few minutes and turn it off.
Connect the usb cable and ethernet cable, Switch on the printer and install the cartridges. If there's no internal problem this will definitely fix your problem.
Good luck.
Thanks for using FixYa.
Jun 30, 2010 | HP Officejet H470 InkJet Printer
FULL DEAD
You can try the following steps:
1. Unplug the power from the laptop and remove the battery then press the power button of the laptop for 15 seconds
2. Put the battery back in, turn on the laptop without plugging the power to the laptop (If this didn't resolve the issue)
3. Remove the battery and press the power button of the laptop for 15 seconds, after that, plug the power cord and turn on the laptop (if this didn't resolve the issue)
4. Remove the power cord and press the power button of the laptop for 15 seconds, disconnect the Hard drive and turn on the laptop (If this didn't resolve the issue) reconnec the hard drive
5. Remove the Optical Drive and turn on the laptop (If this didn't resolve the issue) reconnect the optical drive
6. Remove the memory chip, if you have 2 memory chips installed in the 2 memory slots (remove both of them) now test each one of the memory to each slots turning on the laptop. (If this didn't resolve the issue) Put the memory chip back in
7. Reseat the CPU and try to make sure that it's installed properly. Turn on the laptop and test if it's gonna work (If this didn't resolve the issue)
8. Reseat the power cords coming from the power supply of the laptop and test the laptop. (If this didn't resolve the issue)
9. Disconnect everything and just leave the CPU installed and turn on the laptop.
10. If all else fails, there's a big possibility that the problem may be with the power supply or the motherboard of the laptop.
(Note: you may try to clean your computer if there is a large amount of dust. You may try to remove the CMOS battery)
regards,
sl4x
Feb 13, 2010 | Toshiba Satellite A75-S211 Notebook
Toshiba Satellite P105-S6104: Will not turn on
Power issues are pretty typical with laptops as most time laptops are moved around alot and are not stationary. Here are a few possibliites that could be the reason for you not having power:
1. A/C cord is could possibly be bad. Attempt to use the cord on another outlet, then try to use the same cord on another similar laptop to see if power is transmitted. If cord is faulty, then purchase another cord.
2. A/C input adapter on laptop is faulty. The A/C input adapter is where you plug your A/C cord into the laptop. This can come from the input coming loose or wiring being loose or disconnected.
a. check to see if the part is loose by touching the part with your finger.
b. if you are not a professional, take the laptop to a certifiied computer repair shop.
3. If you are a professional or are comfortable opening the laptop (do bare in mind you opening the laptop yourself violates any warranty you may have), then look at the A/C input adapter to see if it is loose or if a wire was disconnected from the motherboard.
4. If you are a professional or are comfortable opening the laptop, another option would be to check the circuitry on the motherboard to see if there is a bad transistor or circuit on the motherboard.
I hope this was helpful and thank you for contacting the experts.
Jan 08, 2010 | Toshiba Satellite P105-S6104 Notebook
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
Remove battery and disconnect power cord. Press power button for about 5-10 seconds (without battery and power cord) Connect power cord only then turn it on.
Dec 01, 2009 | Toshiba Satellite 2455-S305 Notebook
Toshiba 29A3TA Tv.
Unless you repair tvs ,the only advice for you is to call a repair shop you have something shorted or bad capacitor.
Sep 17, 2008 | RCA F32450 32" TV
Televison & Video Logo
74 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
