Televison & Video Logo
m
marie guarneri Posted on Dec 30, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ineed my blinking remote to work. its not the batteries.
Michel Laprise Sr
Level 2:
Sergeant:
  • Expert 339 Answers
  • Posted on Dec 31, 2019
Michel Laprise Sr
Expert
Level 2:
Sergeant:
Answers
339
Questions
Helped
86814
Points
985
Usually three main problems: 1. The batteries but you already checked that. 2. Programming code has to be re-entered, that is, if you have the instruction booklet . #. What I had to deal more often with is the keypads inside the unit get all "gunked up" and the remote can be opened, the keypads can be cleaned with rubbing alcohol. Also the circuit board where the pads make contact can be wiped dry and you can use a soft eraser to clean the surface. Hope this helps.
P.S: If this is too much, 4. See if a new remote is cheap.
Tv won't always turn on batteries have been changed in remote,sometimes works if unplugged then re connected but not always
To find out if any remote control is working properly do the following:
Turn your phone into camera operation and point it to the remote controls lens. Now you have lens to lens. Push and hold any button on the remote control and watch it threw your phone cameras screen. If the light on the remote control blinks rapidly, then you have a good working remote control. No blinking means dead batteries or inoperable remote.
Remote code for vuz8 remote magnavox blu ray mbp5220f
replace the batteries by new ones
2) clean the contacts batteries with c. cleaner
3) retight the springs contacts batteries, with pliers for a GOOD contacs very importan.
4) open the remote c for clean the KEYpads from corrosion, dirty, dust, oxide, and try again with c. cleaner.
5) reset the code download from www. remotecodelist.com
6) if doesnot work go to the repair shop TV for fix it.
God bless you
Remote for Telefunken tv not working - started giving trouble and worked if one pressed on the batteries, batteries have also been replaced and now not working at all
may be battery not contact well first clean the battery contact and try again if not work pls face the remote controller LED to mobile phone camara and press the buttens you can see blinking LED in your mobile phone LCD screen that means your remote is ok and problen in your tv if you can't see blinking light in LCD means problem in remote
1helpful
2answers
Why does a TV remote control quit working?
Assuming you have changed the batteries, you might try blowing around the edges of the keys with "canned air" spray.
Most likely you can go to a drug store and buy a "universal" remote that will serve as a cheap replacement.
NOTE WELL: check out the "universal" remote's labeling and online to make sure it is compatible with your set BEFORE buying.
1helpful
3answers
Code for panasonic tv
ineed the code for a panasonic ct-27sx12af
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
