Question about The Kitchen Appliances - Others
Can I stuff the turkey before I cook it.and what is a trivel ?
Posted by Donna German on
I’m planning on cooking turkey in electric roaster. I want to stuff bird and cook slowly overnight, is this ok?
hi Connie.
there is lots of ways of doing this.
so i think it best you go to this link and have a read up and see what is best for you to do.
how to cook turkey overnight Google Search
Nov 22, 2017 | Electric Kitchen Appliances - Others
Butterball turkey fryer
Absolutely positively make sure the turkey is fully defrosted. Remove all the stuff they put inside the bird, cook that elsewhere.
Nov 27, 2013 | Masterbuilt 20010611 Butterball Indoor...
How long do I have to cook a 13 1/2 pound turkey in the Rival 18 quart roaster?
This is the site for the manual:
http://www.rivalproducts.com/manuals/MANUALS/RO188BR_43_81844057.PDF
However,
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. Stuffing adds about 2 minutes per turkey pound to the cooking time.
All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 27, 2009 | Rival 18 Qt Roaster Oven with Buffet...
Can I bake a turkey in a baking bag in my Rival 22Qt Roaster Oven (RO230-C)?
It depends on the size of the turkey, because the bag can't ouch the top, sides, or bottom of the roaster. But the roaster already cooks moist, so the bag may ber overkill.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours for an 18 pound turkey. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 25, 2009 | Rival 18 Qt Roaster Oven with Buffet...
What temp should i cook a 20lb turkey in a rival roaster oven model num r01801
This turkey is right on the edge of the size recommended for this roaster, so first, check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. All experts agree that turkeys cook better and safer if unstuffed, so considering that you will have to make an extra pan of stuffing to have it for everyone, you would be well advised to cook your turkey unstuffed and use some of the drippings to flavor the pan of stuffing while the turkey rests.
Nov 24, 2009 | Rival 18 Qt Roaster Oven with Buffet...
I have a 23.5 pound turkey, and a 22 qrt Rival roaster: How long should I cook it and at what temp?
This turkey is bigger than recommended for this roaster, so first, check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
I do not have the book and need to know if I am supposed to pour liquid in the bottom of the roaster when I start the turkey.
No, you never put water between the roaster and the cooking pan/ cookwell/ insert, it actually interferes with the cooking. You can put a little water in the bottom right under the turkey, but the roaster cooks very moist and this is really not necessary.
Check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
Can you cook a stuffed turkey in the roater oven
Yes, similar timewise to a regular oven. But it depends on the size of the turkey, if stuffed you definitely want to check the fit- you need about an inch all around including the top to get good cooking. Any place it touches the sides it will tend to overcook.
The Rival manual suggested 375 for pre basted or 350 for fresh 9-14 minutes per pound. In my experience this is too hot. I use 325 for 4 to 4 3/4 hours at 325 for an 18 pound unstuffed turkey; a 21 pounder takes about 35-45 minutes more. The USDA now uses 165 as the end point temp (down quite a bit from a few years ago), but if you stuff, that has to be in the middle of the stuffing, and the turkey will overcook somewhat while it gets there. It adds about 1-2 minutes per turkey pound if stuffed.
Nov 21, 2009 | Hamilton Beach Toaster Oven with...
Big 18 pound turkey and no manual
Place turkey on trivit in roaster and add 2 cups oof water. place lid on roaster and seal edge with foil. Preheat oven to 500 degrees.  Place in oven for one hour and turn oven off and go to bed.  Turkey will cook while temperature is coasting down.  Turkey will be still warm in the morning.  We have been doing this for several years and always comes out golden brown and juicey.  Do not stuff bird while cooking.
Nov 30, 2008 | Rival 18 Qt Roaster Oven with Buffet...
Kitchen Appliances - Others Logo
87 people viewed this question
Top Kitchen Appliances - Others Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
