Question about Russell Hobbs Irons
How do i remove the back of a russell hobbs colour control iron
5 Suggested Answers
smilemaker
Kanth raj
  • 790 Answers
SOURCE: Faulty Russell Hobbs Steam Iron
http://www.ehow.com/how_2067318_fix-nonelectric-steam-iron.html
Posted on Jan 01, 2008
Anonymous
  • 378 Answers
SOURCE: no steam
its due to not getting appropriate required current to the main board of the unit.also check out any thing got loose on the board .first off all try doing dry /cold solder to whole board it should work if not then check out for the proper current flowing through the resistors mostly 1 of them may be definately faulty and needs replacement. thanks.
Posted on Jan 04, 2009
Anonymous
  • 137 Answers
SOURCE: lost instructions on how to use self clean on my iron
It probably needs to be de-calicified, you can find the stuff to do it at most any hardware store.
Posted on Mar 28, 2009
Anonymous
  • 67 Answers
SOURCE: digital revolution iron squirts brown water onto my clothes
Try an iron cleaning fluid or crystals. you can get the stuff at wallmart or similar stores. It usually works. Try using distilled water in the iron.
Posted on Aug 04, 2009
bozcro
bozcro
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
I would like a repair manual for a Russell Hobbs smartglide 20392 iron as I need to trace a faulty.
Contact Russell Hobbs directly and request a repair manual for model 20392.
Sep 03, 2018 | Russell Hobbs Irons
My Russell Hobbs smart glide iron as stopped releasing steam can you help
Most irons that stop working are a result of minerals deposited inside.
(As the water turns to steam, it leaves mineral deposits inside.)
There may be a chemical you could put in it to remove the minerals,
check on-line or in a public library to see.
Some folks use "distilled water only" to slow this process.
God bless your efforts.
Mar 20, 2018 | Russell Hobbs Irons
Lights come on when plugged in, doesn't heat up and has a beeping sound , colour panel is red thankyou
Read the operator's instructions. They are available of the Russell Hobbs site or by contacting Russell Hobbs UK on-line through the "Contact" link. In most cases, steam irons tend to clog with hard water deposits and need to be de-scaled from time to time. If that doesn't help you, buy a new iron. Rowenta's seem to perform best.
Apr 09, 2015 | Russell Hobbs Irons
Instrution manual for russell hobbs 17880
i need an instruction booklet for a russell hobbs steamglide iron model number 17880 any helpers please .
Jan 20, 2012 | Russell Hobbs Irons
I have so far seen 3 other people with the problem i have with my russell hobbs steam glide iron 13153. I have tried what was suggested to me but nothing has worked. the iron gets hot but no steam coming...
I would write to russell hobbs and complain, my friend bought one of these 18 months ago and hers got hot but no steam through. She sent it back to them and they sent her a new one as a gesture of goodwill.
Aug 04, 2011 | Russell Hobbs 13153 Iron
My russel hobbs iron is allways hot and i cant put it low or warm.
This is a problem with the thermostat- possible that the bimetal is stuck or short or changed in alignment causing the power to be connected at all times and not cutting off.If you can remove the unit then this can be seen by checking the cut off of the control.
Jul 01, 2011 | Russell Hobbs 14084 Iron
Irons Logo
50 people viewed this question
Top Russell Hobbs Irons Experts
NOEL
NOEL
Harrie
AZBen
AZBen
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
