Question about Canon Office Equipment & Supplies
HOW TO REFILL CARTRIDGE FOR CANON PIXMA iP7240 PRINTER
Posted by Ramadhani Mfaume on
ray gallant
    Top Expert:
  • Canon Master
  • 69,148 Answers
You do not buy new ones
Posted on Dec 30, 2019
5 Related Answers
old marine
old marine
  • 2310 Answers
SOURCE: installing new ink cartridge, canon pixma 1600
Go here. Type "how to install ink" in the search box. Click "Search", then select "How do I install the ink cartridge(s)". You will get instructions with pictures on how to prepare and install the cartridges.
Posted on Apr 17, 2008
Anonymous
SOURCE: Canon MP520 cartridge swap and ink refill
Canon MP520 multifunctional device - deactivation of the ink level counter
1. You can do it only when the printer counter releases the warning message - "the ink cartridge is nearly empty" = yellow warning mark
2. You have to do this procedure four times - for every cartridge one times
3. At the screen you will see three warning messages
- for the first one press "OK"
- for the second and third one press "Yes"
4. The fourth message tells you that you can do the ink level counter deactivation by pressing the "Stop/Reset" button (7) for more than 5 seconds. Do it.
Later you can see another type of warning message at the screen:
In this case you can not follow the previous procedure - there will not be any other warning messages.
Just follow the message on the screen and press the "OK" button (5) and you can print.
Unfortunately - I do not know for how long time it works.
You have to manualy check the ink level and refill (change) the cartridge before it is completely empty! You might brake your warranty!
When you insert the new original ink cartridge, the counter will work properly again.
Posted on Sep 14, 2008
Anonymous
SOURCE: How to refill Canon FX3 Laser Toner Cartridge
I drilled the hole on the side with no handle. I put packing tape over the hole and it worked fine. I'm refilling it again right now... Good luck, have fun, and save some $$$!
Posted on Sep 17, 2008
Benifix
  • 5 Answers
SOURCE: refilling of canon ink fine cartridge pg 41
Phew! Finally. This one works for my Canon MP140.
Follow all instructions completely or it won't work....
Power off the printer
Hold the stop/reset button then press and hold power (for 5 secs)
Hold Power and release the stop/reset button
Press the stop/reset button twice
Relase power button
Wait until the power button lights a steady/still green, press the stop/reset button three times with a 3 sec space between each press.
On the 3rd press the inicator should be orange.
Press the power button to set data
To set data remove cartridges then replace.
leave for 20 or 30 secs
Press the power button again to shut down
Then press power button to power up.
The printer will feed one piece of paper through
then set language and counrty.
Then ink should be reset
Posted on Jan 14, 2009
Anonymous
  • 27 Answers
SOURCE: quide to refill canon cartridge 103/303/703
it is very easy
http://www.youtube.com/watch?v=iMiTopIVMxM
Posted on Sep 30, 2010
HOW TO FIX SUPPORT CODE 6000 ON MY PIXMA IP7240
Canon Printer Error Code 6000 is one such error that happens due to some bad situations like any collection of dust scraps within the line supplies, defective line supplies sensor system, scratched line supplies, etc.
Causes of Canon Printer Error Code 6000
1. Improper adjustment of Printer tray
2. Providing multiple paper print commands at once
3. A considerable amount of documents near the printer
4. The line feed is scratched or smeared
5. Faults within the sensor unit or in-line feed slit.
Several users require that resetting or restarting the printer may solve the canon support code 6000 without any problem. But, if the problem continues even after doing so, then follow the steps given in the blog for the solution.
Jun 10, 2016 | Canon PIXMA iP7220 Wireless Inkjet Printer...
Canon mx330 how to change ink cartridges
Use the thumb drill to literally drill a hole into the side of the old cartridge. Make sure to chose a location that's closer to the top of the ink cartridge to avoid over spillage when you add the new ink. Once you have the hole just squeeze in some ink of corresponding color into the hole. Not a huge amount, but enough to get some use out of it before the next refill. I highly recommend covering the hole afterward with a sticker or something so that you don't dry out the cartride. Reinsert the cartridge into the printer and use. (: All set!
*Note: You may have to reset the count on the cartridge to avoid getting messages that the ink need to be changed. From here on in, use your eyes to determine if the cartridge needs a refill (:
Dec 07, 2014 | Apple Nano 69472169 4X130Ml Premium Refill...
My canon ip7240 is saying ink absober full how can i reset it ?
Resetting the waste ink absorber on a Canon printer can resolve some error codes that appear when turning it on.
  1. Make sure the printer is turned off.
  2. Press and hold the Resume button (triangle inside a circle).
  3. Whilst it is held down, hold down the Power button. ...
  4. Keep the Power button held down. ...
  5. Release the Power button.
More items...
Reset Canon Printer ink absorber ' Fix-KB
www.fixkb.com/2011/06/reset-canon-printer-ink-absorber.html canon ip7240 is saying ink absober full how can reset it Google Search
see if this helps you out.
Apr 15, 2013 | Canon PIXMA MP170 All-In-One InkJet...
How to refill ink cartridges
dont refill ink cartridges it may damage your printer and your printing quality.buy original..
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Ink cartridge of canon mp140 printer has run out.can I refill it
Do not refill,the printer works with original cartridge canon.If you refill the cartridge in the future you ruin the printer.
Apr 10, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Please how can i refill a canon printer's cartridge (canon pixma ip2600), without the ink pouring out through the other end
Place the empty PG-30 cartridge on a layer of paper towels on a flat surface.
Use the thumb screwdriver to enlarge the small refill hole just below the letter "B" on the top of the cartridge.
Fill the syringe with 20 ml. of black printer ink.
Slowly insert the syringe into the refill hole that you drilled and release the contents of the syringe.
5
Allow the cartridge to sit upright for 4 hours before inserting into the printer.
Easy!
~KenjiFox
Jan 07, 2011 | Canon Pixma iP2600 Photo InkJet Printer
How to refill canon 38 cartridge
You can't refill the cartridge that's in your printer because your printer remembers the serial codes in the electronics of the cartridge to reject refills. I own a Cartridge World ink refilling store and I have started suggesting that customers buy Canon originals because we have had so many returns.
Dec 31, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
INK CARTRIDGE COLOR NOT RESPONDING TO PRINTER
how to refill pixma ip1000? and how to refill a stylose 3700 model?
Oct 16, 2008 | Canon PIXMA iP1600 Printer
37 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
