SOURCE: Refrigerator trips GFI outlet
unlikely to be the defrost timer. more likely to be the defrost element. try disconnecting the element and see if it trips then. could be of course a wiring fault - frayed wires etc
SOURCE: GFI outlet fuse trips even when nothing is plugged in
hi there, there is a shorted electronic parts at your power supply, fuse allways blows means a shorted diode, regulator and a transistor. it should be replace, do some testing and replace the defective parts. ty
SOURCE: Keeps tripping GFI outlets
The key here is to identify the problem as being either the coffee maker or the GFI receptacle... a simple test can be done as follows...
Try plugging the Coffee Maker into another GFI receptacle .. you may have one in the bathroom? If it trips that too, then you have an internal wiring problem with your coffee maker.. if it doesn;t ..then your GFI receptacle may be bad or on the verge of going bad .. either way..this should narrow the problem down to one or the other.. hope this helps..
SOURCE: My dishwasher keeps tripping the gfi outlet
DISHWASHER SHOULD NOT BE ON A GFI CERCIUT. THATS YOUR PROBLEM . SHOULD BE A DEDICATED CERCIUT BUT IF NOT JUST INSTALL A REG OUTLET DONT WORRY THE DISHWASHER WILL TRIP THE BREAKER IN YOUR PANEL IF THERE IS A SHORT WITH THE WATER.
