SOURCE: How do I remove the washable filter to clean it on my Dyson bagless vacuum?
As you are looking down at the base of the machine (viewing from the front) you will notice a yellow button on the right side just inside of the the wheel area. push up the button to release the casing that holds the hepa filter and the spongy filter. You can see a diagram on your machine which shows this process. After you take the casing from the machine, the round housing which houses the 2 filters will come out of this casing as you pull it off. You can grab the spongy filter and pull it our of the casing. Rinse both filters as shown in diagrams on the side of the casing. Do not use soapy water, just warm water and squeeze out the spongy filter after each new soaking. Let the filters dry for 12 hours and then replace in your unit and enjoy the refurbished air movement. It does suggest that you clean these filters every 6 months.
SOURCE: where is the belt on a dyson upright vacuum?
There is no drive belt on this model - its a cylinder pull along model.
If there's a problem with the turbo brush you can flip open the base of it by removing the screws, check that the toothed belt is in place and there is no clogs of dirt between the turbine and the brush bar.
SOURCE: DYSON DC17 ABOUT 4 YEARS OLD. I HAVE TWO FILTERS
Hi there! This is John from Jerry's Vacuum Sales in Modesto Ca. Are you using any type of carpet fresh product on your carpet? If so the fine powder is leaking onto the filters and causing them to clog. Discontinue use and over time the problem will correct itself.
I hope this was helpful.
SOURCE: Dyson stopped working.
Have you tried starting it again? It might have stopped because it overheated and now that it has cooled it should start again. If not, then possibly the power switch or power cord has failed.
SOURCE: Does my Dyson Animal vacuum have a hepa filter?
The HEPA filter is not a cleanable item. The pre-motor filter is the washable one.
