Question about Measuring Tools & Sensors
My Maxkon N17014 WS-1081 weather station LCD will not work on battery power it's ok when connected to computer via USB
Posted by Glenn Unwin on
Pierce Burgardt
    Welcome Back:
    Visited the website for 2 consecutive days.
Take it apart and get some isopropyl alcohol and a q-tip. check for corrosion around the terminals. If there is none, look for loose connections. If there is something loose, check if a bit of the board is loose. If a bit of the board is stuck to the terminals, give up on batteries.
Posted on Apr 22, 2020
5 Related Answers
mixmaster
Timothy D
  • 626 Answers
SOURCE: Sansa e250 - Won't power up unless connected via USB
Sounds like the battery may have come loose. Remove the 4 screws on the back, remove and reinsert the battery. Charge the device for a few hours. Best of Luck.
Posted on Oct 07, 2007
Anonymous
SOURCE: WS-1510-iT La Crosse Wireless Weather
My 1510-IT came with a faulty battery cover top for the rain guage. There should be a metallic clip mounted to the cover to tie the 2 batteries together electrically. Mine had nothing there. I soldered a wire between the 2 batteries and used some cardboard under the cover to make sure the batteries were pushed down into their holder. Problem solved!
I can't imagine this is systemic but it happened to me.
Posted on Sep 22, 2008
Anonymous
SOURCE: Docking Station problem
I had the exact same problem. When i undocked the laptop i had to reboot it when i put it back, in order to get the USB devices working. By updating the System Interface Driver, located here: http://www-307.ibm.com/pc/support/site.wss/MIGR-67228.html , the USB devices now power back up when you redock the laptop without having to reboot the machine.
Posted on Apr 30, 2009
Anonymous
SOURCE: Discovery Kids digital mp3 boombox does not work
I have solved the issue, well I should say my 2 year old daughter solved it. When you turn it on and the screen remains blank, you have to hold in the green music note button for a couple seconds. Simply pressing and releasing the button does not work, you have to hold it in. I had 2 separate players with this issue and it has resolved it for both.
Posted on Jan 17, 2010
Okeoma Emmanuel
  • 1156 Answers
SOURCE: My weather station by Lacross will not display the
http://www.lacrossetechnology.com/9611/manual.pdf
If that's not the right manual,you can use the link below, and select the model..If the model is not there, that means the manual is not available...
http://www.lacrossetechnology.com/support/manuals.php
Take care
Posted on Jun 15, 2011
Manual for maxkon N17014 weather station
Google (maxkon)(N17014)(manual) without parens.
May 28, 2018 | Office Equipment & Supplies
Batteries for ws 1000 weather station
Search Results
Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for ...
https://www.ambientweather.com/amws1000batt.html Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for WS-1000-WiFi, ... Buy weather stations, wireless weather stations, emergency radios, ...
Ambient Weather WS-1000-WIFI, WS-1001-WIFI, WS-1002-WIFI ...
https://www.ambientweather.com/amwewswestre.html Buy weather stations, wireless weather stations, emergency radios, barometers, ... Ambient Weather WS-1000-BATT 3 x AA Rechargeable Batteries for ...
[PDF]Ambient Weather WS-1001-WiFi OBSERVER Solar Powered Wireless
site.ambientweatherstore.com/Manuals/ws1000wifi.pdf The WS-1000-WiFi weather station consists of a display console (receiver), an all in one sensor ... Locate the battery door on the bottom of the sensor array.
Ws 1000 weather station batteries Google Search
May 26, 2018 | Cars & Trucks
The outside transmitter for my Lacross weather station, model WS-9080U-IT is not working. I replaced the batteries. How do I get it to transmit?
First remove the batteries and wait 5 minutes and then try again. If still no success, make sure that you are close enough to the sensor, take the sensor inside to the readout and see if it picks it up. If it does then there may be interference.
Dec 21, 2016 | Measuring Tools & Sensors
Why does outdoor temperature display only show = signs?
The outdoor sensor probably uses solar energy to charge a battery that powers the wireless transmitter. The battery may be defective or the charging circuit may have failed. The instructions that came with the station could provide some troubleshooting tips.
Nov 03, 2015 | Weather Channel WS-8500TWC-IT Wireless...
Can't shut off alarm totally. It goes off every day. How do I shut it off.
Push the "alm/date" button to display the date instead of the alarm time. If the date is displayed on the LCD, the alarm will not sound.
Jan 06, 2014 | La Crosse WS 9037U IT CBP Wireless Weather...
I can't get my wind speed sensor to communicate with base unit
My PC, only that one not a portable PC, gives noice over USB that blocks communication to windsensor etc. Gives very poor reception with USB connected. Works quite fine without USB..
Dec 24, 2012 | Oregon Scientific WMR88 Full Weather...
Cannot get the weather station model ws-916ou-it to show outside temperature
I have three of these WS-916OU-IT units. After a few years, the outside sensor just fails. You will get dashes and a "TR" low battery signal, even if the batteries are good
just buy another whole weather station (short money) and set both the old and new weather station unit to receive from the single new outdoor sensor.
To do this - just follow the procedure for a single sensor - that is - put the batteries in the new sensor - then within 30 seconds - put the batteries in all the weather stations - they will all pick up the same outdoor sensor.
I now have three units running off of one outdoor sensor.
Seems a bit silly, but it works.
Feb 27, 2012 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
114 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
