Question about Kenmore Ovens
Kenmore electric oven model number c968-69009-1. Reset factory temp, digital controls
Anonymous
SOURCE:
aborcass
Ron Coons
  • 2651 Answers
SOURCE: oven
F2 is aproblem with the oven sensor part number WB21X5301
Posted on Mar 16, 2008
reg501
Richard
  • 413 Answers
SOURCE: Oven's digital temp display too dim to read
The electronic control board will have to be replaced
Posted on Jun 08, 2008
Anonymous
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
Posted on Apr 13, 2009
SOURCE: need part number for electric control panel whirlpool oven
Yes, it is worth $150 to have it done by a pro.
Posted on May 07, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: Kenmore (Roper) digital oven controls have changed
It appears your timer/main controller/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
Find that the oven is so much hotter than the temp. says
The oven temperature can be adjusted so that the dial and true temp are the closely the same. But I need the make, model number and serial number of your stove / oven to tell you how. The number are usually on the door side. J
Jun 06, 2015 | Ovens
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range with ceramic cooktop, model # 79046593500. None of the elements or the oven will heat up. The controls work, the red indicator light goes on, but no heat.
It sounds like your Frigidaire made kenmore may have a power supply issue, the power block that is located at the rear of the oven may be at fault. part number 5303935061. However the digital clock can also cause this problem, and should be diagnosed by a technician.
Mar 14, 2010 | Ovens
The electric circuit breaker kicked off and when it was reset, we are unable to get anything with the oven to work. the time comes on at 12:00 and then it starts beeping and a f 1 light appears
with kenmore F1 is a power failure in side the clock control
your whole clock will need to be replaced
go to www.appliancepartspros.com
type in your model number and look in the control section
Oct 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Flashed F5 when temp is heating up
HI, this code is signaling that your temperature sensor is malfunction. it will result in major damage to the control board and sensor wiring harness if it is not corrected soon. the will allow for high temps during the cleaning process that will ruin the ovens control circuit board.
replace the oven temp sensor soon.
May 19, 2009 | Kenmore 47834 / 47832 / 47839 Electric...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Manual needed for Range operation: Specifically timer reset
I found the work-around to be to decrement the timer to 0 as a means of canceling it, "unset it" if you will.
Dec 10, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric stove
Hello d_i_a_n_a18,
In order to put most ovens into the self-clean mode, there are a series of steps that must be initiated in a specific order. On most units the oven control needs to be set to bake or clean and the temp. control needs to be set to clean and the door lock mechanism must be engaged for everything to work. I would suggest that you consult the user's manual for directions for your specific model. If your manual is not available, check on line at the kenmore parts web-site and you can usually get a PDF version of your manual. Good luck.
Nov 18, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
Top Kenmore Ovens Experts
Marvin
Marvin
Mike
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
