Question about Toshiba Televison & Video
Why does my Toshiba tv screen go from dark to light?
Posted by Keke Y on
David Spradling
    Top Expert:
  • Toshiba Master
  • 12,055 Answers
If you go into picture settings and change but same bad board or screen
Posted on Aug 25, 2020
Aron
  • Toshiba Master
  • 1,807 Answers
The TV's main culprits to be causing this problem are "dynamic contrast" which maybe darkening the backl light in dark scenes an example a night time or a dark scene in a movie. To make the blacks be deeper (as LCD/LED TV are rubbish at blacks) or brighten it on bright scenes to make the light be lighter and once again to make the blacks be deeper so the images pop out. Also "eco lighting" this will dim or brighten the image based on the amount of light in a room in order to be saving energy. Ether way the easy fix is to turn both of these features off. You will get rid of the problem and enjoy more subtler shades of colour that would otherwise be bleached (brightend) or crushed(darkend) out..
Posted on Jul 22, 2020
Toshiba flat screen problem
you lcd tv maybe only to do ajustable the background light more brighter. if no . that will be inverter board need to replace. good luck!
Sep 06, 2012 | Toshiba 46XF550U 46 LCD 1080P Refurbished...
Toshiba tv goes black
the lamp has gone basicly there is a back light that lights the screen if this bulb goes you cannot see anything but it is all still there only way to fix this is to get a new lamp but sometimes the lamp is on a circuit board and the price is more then the tv is worth
Apr 29, 2012 | Toshiba Televison & Video
Sirs: We were just changing channels and the
THE projection bulb is blown if no sound tv probably broken
Jul 31, 2009 | Toshiba 46H84 46" Rear Projection...
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
Screen dark,wont stay on. 52hm95
Here's the online manual for your TV:
http://www.tacp.toshiba.com/tacpassets-images/models/42HM95/docs/42HM95_om_e.pdf
Read the section about the red/green lights in front. It sounds like the lamp went out. Mine consistently goes out once every year to year and a half. If you plan on keeping the television, purchase two bulbs, so you have one on hand in case your new one goes out.
Good luck.
Apr 19, 2009 | Toshiba 52HM95 52" HDTV Projection...
TV screen became a lot darker than normal.
Hi.
yeah, opened the front flap of the TV>menu> brightness> increase. Sorted. No problem.
ain't gonna bother asking any more questions on this forum..........no help at all .
cheers, Pat
Mar 30, 2009 | Toshiba Televison & Video
Dark spots on my JVC 61" tv
dark spot could be a faulty led. if you put a program on that is in white screen you should see all the leds light up the screen. dark spot will be were the led is not working. if on white screen and they all lite up but still dark around the area, it could be the lcd screen. and could be dying pixels. and try this video https://youtu.be/wlA2rcrAOCs
Feb 10, 2018 | Toshiba 55H70 55" Rear Projection...
Toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Screen goes dark
Fading typically is related to power supply heating or connection opening on the digital drive. You might try fan into vents just to prove this, or plug in outside in the cold, and see how long it is on in test mode.
Dec 17, 2017 | Toshiba 50HP82 50 in. Plasma Television
Televison & Video Logo
Top Toshiba Televison & Video Experts
Demonic-2011
Demonic-2011
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
