Cars & Trucks Logo
Tommy Rei Posted on Dec 28, 2019
I have a 02 Chevy trailblazer. When I drive the battery drains the alternator does not seem to be charging it. I have replaced the alternator and battery 2 times now to rule out defective parts. I also tightened down all 4 points on the ground wire. Pulled the plugs on the pcm all pins look clean and straight. Wire dont seem broken. Changed the alternator power and grounds seem fin there as well. I'm stuck any thoughts.
  • CJ Rock
    CJ Rock Dec 28, 2019
    What does the battery voltage read using a DMM while engine running?
AJ Stone
Level 1:
Habit-Forming:
New Friend:
  • Contributor 26 Answers
  • Posted on Dec 29, 2019
AJ Stone
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
26
Questions
0
Helped
5620
Points
90
You are drawing more amps than you are recharging. Is the car stock or modified? Make sure you have the proper amp alternator for the car first.
If you do you will have then have to do a parasitic draw test to find the culprit.
5 Related Answers
Anonymous
  • 1796 Answers
  • Posted on May 08, 2010
SOURCE: battery not holding charge, battery is good and
Hi!!
There should be a split from the cable coming from battery (-) one end goes to the chassis and another one to the block.
My suggestion is to take it to an AutoZone store and have them check the starting/charging systems. Some batteries seem good until you crank the motor and the Amps. are not enough. This is a free service for their customers..
Don't forget to rate this post. Good Luck.
Anonymous
  • Posted on Jan 21, 2011
SOURCE: 1985 Ford Bronco.....alternator will not charge
MY NA ME IS MAGICBROOM58, HAVE YOU TRIED .. I THINK IT'S ON THE FIRE WALL PASS. SIDE (CILINOID) TAKE THE RBBER OFF THE POS. AND TURN YOUR EGNITION OVER TO THE ON POS. GO BACK UNDER YOUR HOOD AND TAKE A RUBBER HANDLED WRECH?SCREW DRIVER AND CONNECT THE 2 POINTS IF IT TURNS OVER U FOUND YOUR PRBLEM
Richard Darley
  • 90 Answers
  • Posted on Nov 23, 2011
SOURCE: pcm is not grounding injectors. need a pin diagram and ground location diagram
Ground points are in different locations throughout wiring harness. If you had any work done to engine it is very possible to have missed one of the grounding eyelets during the process of putting things together. Check along wiring harness in any area you can see or reach to try to locate any loose or disconnected ground looks.
Anonymous
  • 7 Answers
  • Posted on Jan 22, 2012
SOURCE: we have 2002 chevy trailblazer LTZ, we've replaced the battery twice, new alternator, current draw test comes back normal, reset computer numerious times, pulled all fuses and relays, checked all
what exactly is the question ?
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 13, 2012
SOURCE: I think PCM is broken. I measured that 3 and 6 cylinders pin(2) are connecting to ground pin(10). When I cut that wire (3 and 6 cyl.) which goes from PCM to coil engine will start with 4 cylinders but
The chances of the PCM being defective or slim to nearly none.
Jump start trailblazer will run that day but next day it is dead there is a short some where
2006 Trailblazer won't start - Discussion on Topix
www.topix.com > Chevrolet TrailBlazer
Sep 6, 2012 - My 2006 Trailblazer will not start, bought a new battery, still will notstart, not even with a jump. ... i get a jump i drive it and charged the battery it seemed fine but then i went ... Then, next morning, when I turn key, all lights come on and radio... back a day and 360$ well that pos still will crank but will not start. 02 trailblazer a/c problem
Jul 21, 2011
2003 trailblazer key is stuck in ignition
Dec 21, 2009
2003 Chevy Trailblazer will not start
Jul 21, 2009
2002 trailblazers won't start
Aug 24, 2007
More results from www.topix.com
3helpful
3answers
Draining Battery
Check the alternator. You can observe your interior dome light or the vehicle headlights as you rev the engine. If the light intensity changes with as the RPMs of the engine changes, then you have a faulty alternator.
My 2001 chevrolet trailblazer chokes down and dies mainly when i turn on the air conditioner or the heater and my battery wont keep charged very well im not sure if the two problems are related but if
indicates that then alternator is not working and power to drive the ac is being diverted from the ignition system
have an accredited auto electrician check out the charging system( alternator , regulator , load test battery, wiring)
Replace alternator
If you can get it to run, take it to an o'Reilly's or another part house that tests batteries on the car - they do it for free. They can tell you what is wrong.
My Chevy Trailblazer drains my battery and won't recharge it.
I cannot come and see what is causing your battery drain, but I think you might help yourself by removing one of your battery cables each time after you shut off the motor, and reconnecting that cable each time you wish to start the car. Pick the cable that is easiest to unscrew and screw back on. The on boarde computer will not like this solution, but until you find a shop that can fix it, this will at least get you out and home again.
As a test, when you hook or unhook the battery, any spark you see between the cable and the post should be really tiny, or you have a bad short somewhere.
How do i take alternaoter iot of peugeot e7
Go through few Alternator related solved Solutions including replacement of alternator.Select and Click the link below:----How to replace alternator? http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-alternator-on-gmc-sonoma.html
How to test alternator on Dodge Stratus?
http://technoanswers.blogspot.in/2012/02/how-to-test-alternator-on-dodge-stratus.html
How to test and replace Alternator on Audi A4 Car models?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-alternator-on.html
How to Remove Voltage Regulator on Car?
http://vwrepairhelp.blogspot.com/2011/11/how-to-remove-voltage-regulator-on-car.html
HOW TO REPLACE AN ALTERNATOR BELT
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-alternator-belt.html
How to monitor Vehicles charging system? http://repairhelpcenter.blogspot.com/2011/11/how-to-monitor-vehicles-charging-system.html
Car Alternator making noise? http://repairhelpcenter.blogspot.com/2011/11/car-alternator-making-noise.html
After replacing Alternator, the battery indicator light Comes ON dash?
http://howtobyme.blogspot.com/2011/11/after-replacing-alternatorthe-battery.html
How to inspect Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-inspect-vehicles-alternator.html
How to Test Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-vehicles-alternator.html
How to Service Vehicles Alternator?
http://repairhelpcenter.blogspot.com/2011/11/how-to-service-vehicles-alternator.html
How to Replace Alternator? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-alternator.html
Alternator testing? http://schematicsdiagram.blogspot.com/2011/12/alternator-testing.html--------- Cars electrical system is pulsating? http://technoanswers.blogspot.in/2012/01/cars-electrical-system-is-pulsating.html------ 1998 Ford F150 pickup Battery Drains overnight due to Alternator? Alternator drains car battery? http://technoanswers.blogspot.in/2012/02/1998-ford-f150-pickup-battery-drains.html------- 2002 Ford Focus sits over night and battery goes dead? http://technoanswers.blogspot.in/2012/02/2002-ford-focus-sits-over-night-and.html--------- Charging system problem on Chrysler LHS car? http://technoanswers.blogspot.in/2012/02/charging-system-problem-on-chrysler-lhs.html---------- How to replace alternator 1997 Dodge Stratus? http://technoanswers.blogspot.in/2012/02/how-to-replace-alternator-1997-dodge.html------- How to replace Alternator on Mitsubishi Lancer http://www.howtorepairguide.com/2012/10/how-to-replace-alternator-on-mitsubishi.html
These details will help.
For more help.Keep updated.
Thanks.
6helpful
2answers
Battery light on my 2004 chevy trailblazer. It lasted a day then all the ABS breake light came on the the battery drained. The truck shut off. What could this be. I bought a brnad new battery 2 years ago.
The battery light comes on when there is an issue with the charging system. Most likley you have a bad alternator. With the engine running you should see a min. of 13.5 volts at the battery and better yet 14+ volts. If you have 12.5 or less than the alternator is not charging.
Once the vehicle is started the battery is no longer in play. The alternator is what keeps the power supply to the vehicle and recharges the battery for the next time you want to start the vehicle. Once battery voltage drops below 9 volts or so systems start to shut down. Eventually the battery will drain enough that the engine management system can no longer function and the vehicle will stall.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Changed belt on 02 trailblazer now it won't start
Belt turns alternator, alternator charges battery.(no belt, no charging) Charge battery with a charger. Though it may start with a jump, the alt is designed to maintain the state of charge in the battery, not to fully charge it . Therefore jumping puts too much demand on alt and can damage it. or will shorten battery life considerably.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
