Question about Furniture
I have a Panasonic Ep3513 Massage chair. It turns on and does a body scan, then it starts into tapping mode quickly then turn off. Can someone help me with this. It's been this way for several years. Trying to get it going again.
Posted by Arlyn Tratt on
JonSnell Electronic
    Top Expert:
  • 31,770 Answers
Check the batteries/power supply.
Posted on Jul 31, 2020
5 Related Answers
Kimi
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
Anonymous
  • 80 Answers
SOURCE: Problem - Turn off and turn on again - happens repeatedly
We see this camera often because the lens gets compressed some how and the plastic gears which drive it become damaged, this would be the "buzzing" noise you're hearing during power up. The camera is not passing its power up diagnostics and therefore it shuts down. The lens is not cost effective to replace on this camera, parts and labor exceed a replacement units cost. Hope this is some help. Good Luck Joe Weibel Custom Electronics (customelectronics.org)
Posted on Feb 13, 2007
Anonymous
  • 2600 Answers
SOURCE: computer shuts off in safe mode when trying to run scan
You are still infected. You need another computer to download the program to and then put it on a flash drive, then install the program on the infected computer with the flash drive and run it. Click on the link below for the program I use. You did not tell us what you already tried, but this program is good for disinfecting 95% of the nastyies out there. Intsll and let the program update. Run the quick scan only and when the scan is complete it will ask you to click on the "show results" button, do so and it will list all the infections on your system. Click on the "remove Selected" button, this will either delete, fix or quarentine the affected files.
http://www.filehippo.com/download_malwarebytes_anti_malware/
Posted on Jan 28, 2010
Testimonial: "I can't thank you enough. I know just enough to click myself into trouble and not enough to get out of trouble when I get there. All great now!"
Anonymous
SOURCE: need help folding my peg perego high chair, its the rocker kind?
i fold my pegperego high chair how to return in original position?
Posted on Nov 07, 2010
thedubman129
SOURCE: I have a Sharper Image massage chair model HT-270
the beeping means that the remote needs to be replaced. check the wire for bit marks or pinches. they are user replaceable. just go to the human touch website and call their numbers
Posted on Aug 17, 2011
What is an electric air massage chair?
The air massage is a relatively new method of massage that is offered in electric massage chairs. Inside the padding of the chair are air bags that inflate and deflate on certain areas of your body, usually on your arms or legs. The inflation makes a squeezing effect, which can feel very nice and can help to improve circulation to the area being squeezed.
Dec 25, 2012 | Furniture
When was the first vibrating chair made?
Massage chairs were first brought to market in 1962 by the Family Inada company. Today, Japan is the largest consumer of massage chairs with some surveys suggesting that over 20% of Japanese households actually own a massage chair. By comparison, massage chair penetration in the US market is estimated to be in the neighborhood of 1%. The current massage chair market is dominated at the top by a three dominant manufacturers: Fujiiryoki, Family Inada, and Panasonic. After the purchase of Sanyo by Panasonic, Panasonic announced plans to eliminate Sanyo as a brand for all current Sanyo consumer products.
What is an electric massage chair?
An electric massage chair is a type of chair that gives you a massage (using internal electronic motors and gears) while you sit in it. They are usually made of high quality materials and really expensive (cost thousands of dollars).
Sep 09, 2012 | Furniture
Massage starts then stops after 10 seconds
I suggest that you contact Panasonic directly and ask them how you could fix this. Also, you can get in touch with the store you got it from and possibly ask for a new massage chair.
Here's Panasonic contact page: http://shop.panasonic.com/support/
Aug 29, 2012 | Panasonic Real Pro Ultra Massage Chair...
What is the difference between a Swedish massage chair and a Shiatsu massage chair?
A Swedish massage chair incorporates five different stroke patterns (sliding, kneading, tapping, vibration and friction) across muscles groups; while a Shiatsu massage chair combines pressing, swaying, patting and rolling movements while targeting pressure points.
Aug 06, 2012 | Furniture
Furniture Logo
160 people viewed this question
Top Furniture Experts
John Tripp
John Tripp
Tom Chichester
Are you a Furniture Expert? Answer questions, earn points and help others
