Question about Mitsubishi Televison & Video
Mitsubishi 60 TV Needs a sound bar. Only audio output is RCA Digital Audio Output. Is there an adapter to go to a 3.5m plug to plug into the sound bar?
Posted by Walter Burger on
Andrew Taylor
    Top Expert:
  • Mitsubishi Master
  • 33,973 Answers
Yes, but that projection television is a dinosaur!
Amazon
https://images.app.goo.gl/dkCB5z3ZaG1hTEvWA
Posted on Aug 21, 2020
5 Related Answers
simplemitch
Mitch
  • 752 Answers
SOURCE: LCD HDTV digital audio output jack
The orange jack is a DIGITAL audio out and cannot be hooked to anything other than a digital input. You want to use the White/Red jacks at the bottom.
Posted on Sep 12, 2007
tvtek
Duke
  • 1284 Answers
SOURCE: Digital Audio Output on TV
When using HDMI as the source, the Dolby Digital data will NOT be passed through. If you switch your cable box or satelitte receiver to PCM audio it will pass that through.
Posted on Feb 21, 2008
skotkolr
Scott Hill
  • 558 Answers
SOURCE: Trying to connect digital audio output optical terminal to existing analalogue hi-fi amplifier
there should be on the tv out a red and white rca output or a coaxial, your yamaha my be too old to deal with the outputs on the tv. at the jvc website you can download the manual for this tv.
Posted on Apr 27, 2008
Bob Citizen
  • 520 Answers
SOURCE: digital audio out jack
That output only works with digital signals (digital tv channels and digital audio from the hdmi in jack).
The HDLCD2600 has no analog out. Sorry.
Posted on Oct 23, 2008
Turk_97
Ian Kayhan
  • 138 Answers
SOURCE: Unable to access digital audio output options
Well you also need to have a digital feed to the television. example: When I run my optical cable from my dvd player to my television directly. I went in to my menu options on my source and enabled this. If you are wanting to run this feed to your a/v amp? You may want to run the original feed from your dvd player to your amplifier directly, you will get a sound quality that is far superior to what you seem to be doing here.
Posted on Sep 24, 2009
How dd I connect my soundbar to my TV using the red and white RCA plugs
Hello. On the back of your TV look for RCA Audio jacks marked "Audio Out". Connect the cables from that to the RCA Audio Input on your sound bar. If your TV doesn't have the RCA outputs, see if it has an optical output. Your sound bar probably has an Optical Audio input. You would need to buy an optical cable for that.
Aug 15, 2015 | RCA Televison & Video
Where do I plug HDMI cable to a soundbar. I have 3 HDMI inputs but no output
Hello. Your Mitsubishi doesn't support HDMI ARC (Audio Receiver Channel). You will have to use the AVR or the Digital Audio output to connect your sound bar. Sorry.
Aug 13, 2015 | Mitsubishi WD-60737 60 in. HDTV
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Want to hook up a philips sound bar to my t.v. what cable do I need and where do I plug in at
Which model TV and which model sound bar do you have? Some Sansui TVs have a coaxial digital audio port and a 3.5 mm headphone port; this is true for the SLED2480. Some of the smallest Sansui TVs may only have a headphone out option or no audio output. These jacks will be on the back or the side depending on the model. For some Sansui models, these will be easiest to see when you put the TV on its face (on a clean soft surface) and look next to the base of the TV.
The Philips CSS2123B/F7 has a digital coaxial port, a digital optical port and RCA analog inputs on the back of the unit. It also has a 3.5 mm input on the right side for connection with auxiliary devices (like a headphone out). Other models may have different ports.
Thus the cables you need will depend on the specifics of your devices; similarly the locations of the ports will depend on the models. If your TV only has a headphone out and the soundbar has analog audio inputs, you will probably want a 3.5 mm to RCA audio adapter. There are several options depending on whether you want to use an 3.5 mm audio cable or an RCA audio between the TV and the soundbar. (Pick a cable and then get the adapter to plug into either the TV (M 3.5 mm to RCA FF) or the soundbar (2 RCA MM to 3.5 mm F).) There are 3.5 mm M to RCA MM cables as well.
If your TV has an digital audio outputs, get the correct cable (optical or coaxial) and connect that to the port on the sound bar and TV.
Please add a comment with the model of your TV and soundbar for specific information. I hope this helps.
Nov 30, 2013 | Sansui Televison & Video
How can I connect a sound bar?
Buy a digital optical cable and plug it in the audio output of the TV and into the audio input on the sound bar. If there is no digital input you can run it with a RCA cable (3 cable red, white, yellow) or just simply an HDMI cable.
SONY eSupport How to connect TV Sound Bar system to television
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gregg_27a4d257e54e7920
Feb 15, 2013 | LG 42CS560 42 Class LCD HDTV
Hi.How can I connect SHARP HT-SB400 sound bar system to TV SAMSUNG UE40C6000 LED? I have RCA cable supplied by sharp, it's that possible? My SAMSUNG operation system is : T-VAL6DEUC-1016.0
You should be able to connect these but you'll need some extra adapters/converters/cables. The Sharp HT-SB400 has analog audio inputs (http://www.sharp.co.uk/cps/rde/xchg/gb/hs.xsl/-/html/product-details.htm?product=HTSB400&cat=10500 ). The Samsung UE40C6000 LED TV has a digital (optical) output and a headphone jack (http://www.samsung.com/uk/consumer/tv-audio-video/television/led-tv/UE40C6000RKXXU-spec ).
With a RCA (F/F) to 3.5 mm (M) adapter, you may be able to connect the headphone audio out to your sound bar directly. This is an example: http://www.cyberguys.com/product-details/?productid=4730 . I'm not sure if this will automatically disable the TV speakers.
The other option is to get a digital audio to analog audio converter. One of these is http://www.amazon.com/Digital-Audio-Analog-Converter/dp/B0013LWK3A . You'll also need the optical digital cable in addition to the RCA audio cable that you have. With this you'll have to follow the manual for turning on the digital audio output on the TV (under the Sound menu) and turn off the TV speakers.
I hope this helps.
Mar 04, 2012 | Sharp Audio Players & Recorders
Connectding audio/video cables when you have a cable box and sound bar with dvd player
How To Connect a DVD Recorder to a Television:
1.If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
2.To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
3.To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
5. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
6. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
7. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
8. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
9. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
10. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Oct 17, 2011 | Televison & Video
HOW I CAN HAVE OUTPUT FRO AUDIO LINE ROM LG 55LH5000???
Hi, sorry but Most LG's no longer have audio outputs. The easiest way to get it ,You need to take the audio output from the source i.e. "cable box output"..if you have of course...
However whether your TV has this output or not we need to make some tests..5 different connections possibilities provided below.
(not by priority..you can start with any of it ).Below ,there is a sample TV back panel picture as well
Possible CONNECTIONS:
1) 2x RCA ports red / white is audio out ( L + R ) of TV to Stereo..
2) You can get also the audio digital output from the TV to a A/V receiver. the tv's optical audio out is stereo only mainly designed for freeview or tv audio to be output,
set the audio ouput on the TV menu to Dolby Digital, connect a digital optical out directly to the A/V receiver to receive audio signals.
3) since your TV has :2 x HDMI, SCART, AV, Component Video, VGA-sub, USB 2.0, connections,you may use the SCART plug to get Audio output for your TV .
TV's SCART connector which has 21 pins and "2x Audio Output " pins should be in it.
you need to buy an adapter called " RGB Scart Male to 3 RCA AV Female Adapter Converter" that can easily be found any electronic Market..one example as found eBay URL is below..
http://cgi.ebay.com/RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter-/130389078197
After you get this adapter,you need to carry the audio signal from SCART's RCA plugs to your Receiver with a 2x RCA (white/red ) cable.(if this does not work ,mfg should state somewhere in the manual..as your TV's "SCART socket IN only" ) if you properly connect IN/OUT plugs you will able to get the audio signal of the TV thru stereo..I recommend 2 $ value "RGB-Scart-Male-3-RCA-AV-Female-Adapter-Converter" with IN/OUT switch on it.
4) use HDMI connection of TV if you have HDMI input on your stereo of course...
5) if these are not an audio-out on one of these connectors , so you'll need to use the headphone socket if you want to plug it into a stereo. you need a cable 2x RCA to 3.5mm Headphone jack.
( This is the last ditch solution , since it mutes the whole sound.) ..
NOTE: if you connect this, pls be careful,your TV voice level will drive the stereo volume....
Hope this helps!..if more help requires Would you please let me know the result ?
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for us
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
How do you connect a vizio sound bar to the tv
plug in the power to each unit with the provided power adapters, turn the sound bar and subwoofer on, activate the wireless subwoofer link by pressing a button on the soundbar (or remote) and subwoofer, and connect an audio source to either the provided analog or digital audio inputs on the soundbar
Note: When using the Digital Optical input, set source device audio out to PCM
(you can hook to ur tv if it has a R/L audio output, or u can also connect it if your tv has a toslink style digital output. (most LCD and Plasma TV's have them.))
Dec 31, 2010 | LG 47LG50 47 in. LCD HDTV
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
Televison & Video Logo
78 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
