Question about Denon Audio Players & Recorders
Denon 5 disc DCM 520. The "loaded" disc is jammed and cannot spin however can open the drawer. Do you have any suggestions and or steps to remove the case to access the disc to unjam. Thanks
Posted by Phil Henrich on
5 Related Answers
Anonymous
  • 151 Answers
SOURCE: Tray won't open
Have a professional open it up to check so not to further damage the device. If you want to do it your self, you can open it up, just make sure your warranty is not void by doing so...
A possibility is that the tray has a lodged cd in it...
Posted on Dec 10, 2007
Anonymous
  • 75 Answers
SOURCE: i face a paper jam a lot, what is the right steps to release it?
remove the sensor which detetcts the paper jam and clean it and again install it...
Posted on Jul 29, 2008
Anonymous
  • 750 Answers
SOURCE: Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Posted on Sep 25, 2008
jason michael
  • 106 Answers
SOURCE: Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Posted on Mar 22, 2009
Anonymous
  • 3 Answers
SOURCE: Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Posted on Aug 03, 2009
How to remove a jammed cd out of a car cd player
I hope you don't use the DCM-360 in your car. You should be able to eject the CD, with pressing the eject button, several times. It could be the eject mechanism is defect, or someone pressed the CD too far, r even some debris came in the player, after the ce was inserted.
In most cases, you really should remove the player en open it. to avoid more damage than already exists
May 02, 2014 | Denon DCM-360 5-Disc CD Changer
My DCM-360 has stopped playing discs after my moving house. It spins the carousel, picks up the disc and then puts it down without spinning the disc up. Laser problem or disc-spinning-motor problem or...
Had a similar problem with my Denon. When I inserted CD it takes it in but immediately stops - like it doesnt sense the CD. Same problem with Single or Multi changer. Removed cover, removed reader ( 4 screws) and found lens had fallen out. Cleaned, reinstalled with touch of super glue on rim - works fine.
Oct 12, 2010 | Denon DCM-360 5-Disc CD Changer
CD carousel won't rotate. Opens and closes fine, but will not change discs in either the open or closed position.
gears may have something obstructing them. Check and clean with dustaway. Gears may be broken jammed or slipping belt.
Apr 06, 2010 | Denon DCM-360 5-Disc CD Changer
The tray is jammed in and I can't get it to open or do anything.
Try taking the unit apart and see what could be causing this.
Dec 06, 2009 | Denon DCM-360 5-Disc CD Changer
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Denon DCM 5000 error code
The disc is loaded upside-down in the disc rack or the disc is dirty or scratched, try another disc and make sure the top side (label side with printing) is facing towards the back of the rack, away from you. The bottom or data side should face out towards the front of the rack. If that does not work then your laser picups inside may need cleaning. Make sure your disc is clean and now scratches.
Feb 08, 2009 | Denon DCM-5001 100-Disc CD Changer
Denon DCM 370 5 disc changer does not show all discs!
Probably drive belt that rotates the carosel inside is not lining up properly,or the belt that moves the laser mech into position,sounds like its just not lining up properly
Jan 04, 2009 | Denon DCM-370 5-Disc CD Changer
Cd changer is jammed in denon dcm 360 5 cd changer
Simply remove the outer casing and remove the jammed disc
Nov 28, 2008 | Denon DCM-360 5-Disc CD Changer
121 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
