Hk3400 stuck in tape mode - Televison & Video
Posted by Tl Lewis on
Anon
  • 1,438 Answers
Insert a thin, flat-head screwdriver beneath the VHS tape inside of the deck. Very Gently pry upward on the tape until it comes free from the tape deck's heads. Grasp the tape with a pair of needle-nosed pliers. Pull the cassette out of the deck.
Posted on Jul 30, 2020
Why does my RCA VR667 not accept a tape and returns a eject or stop message?
A couple of reasons. First the carriage the tape sits in is damaged. Next the mechanism that moves the tape is damaged and can't except a tape. Lastly or perhaps due to the later, the mode switch is faulty or not in the right position. The mode switch tells the electronics which position the mechanism is in, be it play, fast forward or eject etc. If the switch is faulty and stuck in eject then it wont except a tape.
May 11, 2014 | RCA Televison & Video
Harman kardon hk3400
2137506d-0d6a-4691-80f8-bed3f79f59bb.jpgYou just need one of these. And a spare socket on the receiver. The 3.5 jack plugs into the headphone socket of the iPod.
May 29, 2013 | Audio Players & Recorders
Stuck in tape monitor
There is a problem with the switch not Engageing with the circut board.
Dec 04, 2012 | Technics SA-EX300 Receiver
Ag7750 stuck in still error 5
Transport mechanism problem if tape will not ff/rewind----possible drive belts or the direct drive idler wheel that moves the tape.
Oct 31, 2012 | Televison & Video
I Press Play Button, And Tape Goes Into Fast Forward Mode
Pinch Roller linkage is stuck. Clean and regrease and it will work right again- I have done hundreds of them
May 01, 2012 | Teac Audio Players & Recorders
JVC CR-6060U Stuck in 'Search' mode
TAKE IT APART CHECK TO SEE IF ANYTHING IS STUCK,,TRY A JUNK TAPE ,,,,BLOW OUT ANY DUST ,,USE A HEAD CLEANER WITH ALCOHOL
Feb 06, 2009 | Samsung VR8460 VHS/S-VHS playback VCR
Tape stuck in cam corder
take a screw driver and open it up.
Dec 04, 2008 | JVC GR-D30U Camcorder
Emerson ewd2203 video/dvd combo
Do you know why the tape was stuck? How did you get it out? On most vcr's there's a mode switch connected to the mechanics of the vcr. If the mode switch isn't in stop position, the unit will try to get it there and shut off if it can't. Bad belts, bad idler wheel, dirty mode switch, mechanical timing off (maybe due to forcing a stuck tape out?)... all these can cause this.
Geno
Feb 27, 2008 | Emerson EWD2203 DVD Player/VCR
Safe guard mode
Hi my name is Erick . Have you tried ejecting the tape??? Safe mode just means the tape is stuck or something in the mechanicism is not letting the gear works eject the tape. GOOD LUCK!!!!
Oct 23, 2007 | JVC GR-SXM470A S-VHS Analog Camcorder
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
