Question about Lands Phones
PANASONICSO KX TGA421HOW DO I CALL FORWARD - Lands Phones
Posted by Frances Whitfield on
How to forward all calls on KX-TG6702
The KX-TG6702 is a standard POST 2-line landline cordless telephone system. You can transfer a specific call between handsets using the Intercom without changing the line that the call came in on. Then you can use the second line for other calls, if the wiring and phone subscription is set up for that. However, if you want to forward any call to another phone number, you will need to connect your telephone provider and set up call forwarding. Follow the directions from the provider to use the service.
The manual for the KX-TG6702 is available on the product support page: http://shop.panasonic.com/support-only/KX-TG6702B.html . The direct link to the manual is currently ftp://ftp.panasonic.com/telephone/om/kx-tg6700_en_om.pdf .
I wish that I had better news for you.
Jul 16, 2018 | Lands Phones
FWD/DND will not cancel on KX-TDA200
Hello,still having the same problem?I can remotely configure and cancel call forward and configure your system as you want it.Contact me for help.
Mail me: [email protected]
Make the subject be PANASONIC PBX
Aug 21, 2012 | Panasonic (KX-TDA200)
How do I turn off call forwarding
http://www.ehow.com/how_4794323_turn-off-call-forwarding.html
ok.this article is usefull!!!
pc tablette
tablette tactile
Feb 28, 2012 | Panasonic (640005) for KX-TG2700S,...
How do you put a panasonic KX-T6730 on voicemail instantly if you need to leave the office early?
Press
Dial 50(forwarding program number) on the keypad
Press or
Dial one of the following single digits for the condition you want
0-off
1-DND(Do Not Disturb)
2-All calls forwarded
3-Busy calls forwarded
4-No answer calls forwarded
5-Busy/No answer calls forwarded
Dial the voicemail access code(default is usually 500; this is the number that will ring voicemail)
Press or
Lift handset or press to end
Dec 10, 2010 | Panasonic KX-T7630 Corded Phone
KX-TGA109EX how to call forward?
Call forwarding is a feature from the phone company. Depending on the phone company it's usually 72# or *72 plus the number you're forwarding to. 73# or *73 cancels it. Check with your phone service provider for the specific codes for your service.
Apr 22, 2010 | Lands Phones
Call forwarding on Panasonic Kx-T7633
I have a KX-T7633 and I want to be able to forward calls to my mobile after approx 3 to 4 rings when not answered
many thanks
Fintan
Nov 19, 2008 | Panasonic KX-T7633 Corded Phone
Cacelling forward
To remove forwarding, lift your handset, push the FWD/DND key and dial 0. Here is the quick manual for that model - http://service.us.panasonic.com/OPERMANPDF/KXT7720.PDF
Feb 03, 2008 | Panasonic KX-T7730 Corded Phone
How to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
Sep 03, 2007 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
106 people viewed this question
Top Lands Phones Experts
Marvin
Marvin
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
