Question about Bissell Vacuums
How to replace motor on bissell quickstream - Bissell Vacuums
Posted by donna pulling on
Andrew Taylor
    Top Expert:
  • Bissell Master
  • 33,433 Answers
Motor needs replacement
Most manufacturers have all that information on their websites. Try visiting Bissell's website and in the search bar, type in "motor wiring diagram".
Apr 20, 2014 | Bissell 4104 Bagless Upright Cyclonic...
Brush motor needs replacing
Hey, you may want to contact one of BISSELL's Authorized Service Centers for assistance with the brush motor.
Here's a quick link to locating one in your area:
http://www.bissell.com/service-centers/?cid=ccsocial
Mar 05, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
Noisey 69p3e
mine has the same problem for the 3rd time, each time Bissell have so far just replaced the motor. The motor will continue to increase in volume until it finally has enough and goes bang! The next problem now seems to be able to get a replacement motor other than sending the vacum back to Bissell...
Aug 25, 2012 | Bissell Vacuums
My pump motor burnt out I need a part number for a replacement one. I have the little green bissel 1729-1. It is about 7 years old.
Good after,
The item# for the pump motor is not listed in the user guide or anywhere else on Bissell's site:
http://www.bissell.com/assets/0/132/134/228/2b48eb5a-312d-43be-b570-9f7012a773a8.pdf
This might be the kind of situation where you should contact your nearest Bissell service center. You can do this by putting in your zip here:
http://www.bissell.com/customer-support/
Let me know if you need more clarification. Hopefully this will get you started. Please rate this solution!
Thanks,
~PCF
Mar 05, 2011 | Bissell 1720-1 Little Green Wet/Dry Vacuum
Same here too!
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ar2
Jul 13, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
BISSELL PROHEAT 2X 9200E - BRUSHES WON'T TURN
Hi there if u have already replaced the brush motor and the brushes stil aren't rotating, you wil need to also replace the circuit board that is located in the upper part of the machine after u take the 5 screws out the back, hope this helps, I repair bissells for a living so any problems email me, [email protected]
Apr 05, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I am looking online for a replacement motor for my Bissell ProLite 3560-2 upright vacuum. I have found two different part numbers and do not know how to determine which is the correct one. 2146060 or...
The bissell website has a user manual http://www.bissell.com/images/UserGuides/prolite.pdf and it states the motor is warranteed as follows...Note the section pertaining to the motor... that may apply to you...
Warranty
This warranty gives you specific legal rights, and you may also have other rights which may vary from state to state. If you
need additional instruction regarding this warranty or have questions regarding what it may cover, please contact BISSELL
Consumer Services by E-mail, telephone, or regular mail as described below.
Full Three-Year Warranty on BISSELL ProLite Vacuum Parts
BISSELL Homecare, Inc., upon receipt of the product, will repair (with new or remanufactured components), or if repair is not
possible after a reasonable number of attempts, either replace (with new or remanufactured product) your ProLite Vacuum, or
refund the purchase price, which ever you prefer, free of charge, for THREE YEARS from the date of purchase– any defective
or malfunctioning part.
This warranty applies to product used for personal, and not commercial or rental service. This warranty does not apply to routine
maintenance components such as filters, bags, or brushes. Damage or malfunction caused by negligence, abuse,
neglect, unauthorized repair, or any other use not in accordance with the User’s Guide is not covered. See information below
on “How to obtain service for Your BISSELL product for Service”.
Limited Warranty 0n BISSELL ProLite Vacuum Motor Housing
Subject to the *EXCEPTIONS AND EXCLUSIONS identified below, BISSELL will repair or replace, (with new or remanufactured
components or product) at BISSELL’s option, free of charge, from date of purchase by the original purchaser, for:
Five (5) Years – a defective or malfunctioning Motor.
Ten (10) Years – a defective or malfunctioning Motor Housing.
*EXCEPTIONS AND EXCLUSIONS FROM THE TERMS OF THE LIMITED WARRANTY
THIS WARRANTY IS EXCLUSIVE AND IN LIEU OF ANY OTHER WARRANTIES EITHER ORAL OR WRITTEN ON
THE BISSELL PROLITE VACUUM MOTOR AND HOUSING. ANY IMPLIED WARRANTIES WHICH MAY ARISE BY
OPERATION OF LAW, INCLUDING THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
PARTICULAR PURPOSE, ARE LIMITED TO THE THREE-YEAR DURATION FROM THE DATE OF PURCHASE AS
DESCRIBED ABOVE.
Some States do not allow limitations on how long an implied warranty lasts, so the above limitation may not apply to you
If your BISSELL product should require service:
Call BISSELL Consumer Service at 1-800-237-7691 and we will give you the name and address of an authorized
BISSELL Service Center in your area. If there is not an authorized BISSELL Service Center in your area, one of our
Service Representatives will be happy to assist you. You can also visit the BISSELL website - www.bissell.com to
locate a Service Center near you.
For information about repairs or replacement parts, or questions about your warranty, call:
BISSELL Consumer Services
1-800-237-7691
Monday - Friday 8 a.m. — 10 p.m. ET
Saturday 9 a.m. — 8 p.m. ET
Or visit our website @ www.bissell.com
When contacting BISSELL, have model number of unit available.
Please record your Model Number: ___________________
Please record your Purchase Date: ___________________
NOTE: Please keep your original sales receipt. It is your warranty.
It is suggested you staple your original sales receipt to the
front of this guide.
Filtrete and 3M are registered trademarks of 3M Co.
Warranty
©2004 BISSELL Homecare, Inc
Grand Rapids, Michigan
All rights reserved. Printed in USA.
Part Number 310-6004
Rev 4/04
Visit our website at:
www.bissell.com
ug310-6004_3561_404.indd 12 4/29/04 8:29:16 AM
Sep 21, 2008 | Bissell Vacuums
Bissell vacuum problem
the motor as a cut out switch ,if the motor housing is full of dust , the motor will get hot and the switch will activate ,
Nov 20, 2007 | Bissell 3594 CleanView PowerTrak Bagless...
Vacuums Logo
121 people viewed this question
Top Bissell Vacuums Experts
Marvin
Marvin
Mike
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
