Question about Canon Office Equipment & Supplies
I want to align my print head of Canon PIXMA TS3100 series TS3120 wireless printer. Please take me through the steps to do this. thank you.
Posted by Joyce Kitt on
  • Canon Master
  • 6,162 Answers
Do you want to do the print head alignment from a computer or from the printer? If you are using a computer, what OS is installed and did you install the Canon full software package?
In any case, first load the printer with A4 or letter size white paper (at least two sheets) and make sure to set the paper size to that format. Make sure that none of the ink cartridges are reporting low ink. If a cartridge is low, replace that ink cartridge before continuing. (The printer must be on.)
If you are doing the print head alignment from the printer, press the Setup button (with the screw driver and pliers) several times until 4 is displayed on the LCD. Press the Black & White or Color copy button. Once the alignment sheet has been printed, carefully pick up the sheet without touching the areas with ink. Place the sheet print side down on the scanner glass. Make sure that the alignment mark on the bottom right corner is aligned with the alignment mark on the corner of the scanner frame (left side of the printer near the hinge of the document cover). Close the document cover and press the Black & White or Color copy button. Wait for the flashing lights to stop before moving the document cover or alignment sheet. If you see the Alarm light flash, press OK and take the appropriate action based on the error message.
From a Windows OS computer, open the Canon LJ Printer Assistant Tool. Click the Custom Settings link. Check the box for Align Heads Manually and check any other appropriate settings. Click OK and then OK for Apply these settings to the printer. Press Start on the Print Head Alignment. Do not open the printer cover. Once the alignment sheets are printed, look them over and answer the questions on whether the alignment looks correct for all of the rows and columns. See https://support.usa.canon.com/kb/index?page=content&id=ART167892&actp=search&viewlocale=en_US&searchid=1577398967983 for the pictures of the correct alignment sheet.
From a Macintosh, you need to use the Remote UI. Then select Utilities and then Auto Head Alignment. Follow the on-screen directions.
I hope this helps.
Posted on Dec 26, 2019
5 Related Answers
Anonymous
  • 47 Answers
SOURCE: Error 5100 - what does this mean?
Hi Luza, A 5100 error is a carriage problem. That means it could be the code strip, carriage assembly or logic board. First make sure nothing is keeping the print head from moving all the way across the printer. If the smallest thing blocks the head from going all the way across it will generate this error. You'll want to look hard for ANY obstructions anywhere. Throughly check the gears and rollers for obstructions too. Second the code strip (or timing strip) is the 1/4 inch plastic strip that runs across the printer and through the head carriage. It's got supports on both sides. If becomes dislodged it will generate this error. (it's got a tesnsion spring on one end) I have a feeling that is your problem. That somehow when you replaced the cartridges you may have dislodged the code strip. That might account for not being able to correctly align the print head too. Make sure it's straight, level and secure. Also make sure it's not dirty. Grease or dirt on the code strip can generate a 5100 error. You can clean it with a damp cloth (water) but be careful if your going to remove it from it's anchors. You can try cleaning the steele bar that the carriage runs across as well, but you'll have to lube it back up with a cloth dampened with some 3 in 1 oil or a light machine oil. If none of that works and your ABSOLUTLY SURE there is nothing in there blocking the printer then it must be either the carriage assembly or logic board. If either is the problem you're going to need service on the unit or a new printer. I hope this helps. Please let me know how you make out, Dude
Posted on Nov 17, 2006
old marine
old marine
  • 2310 Answers
SOURCE: Using the Canon PIXMA MP240 printer wirelessly
In order to do this, the laptops have to be able to communicate with each other wirelessly. I.e., you have to have a wireless network set up. If you do, then you are "printer sharing", using one laptop as the 'printer server' (with the printer connected to it) and the other as the 'client'. Step by step instructions are available at this link. Type "printer sharing" in the search box in the center of the screen and click on the Search button. Select the option that matches your requirements.
Posted on Jan 12, 2009
Anonymous
SOURCE: Alignment of printhead on Canon Pixma iP4600
This is simply a case of the ink tanks not being pressed in hard enough. They do click in, as the manual instructs but, unless they are fully pressed in top and bottom, this problem occurs. It's a shame that the Canon manuals and even the support centre do not mention this simple solution.
Posted on Jan 26, 2009
Anonymous
  • 787 Answers
SOURCE: Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Posted on Oct 15, 2009
Anonymous
SOURCE: printer cannot print-message (5B00)
it says check printer 5B00. what do I need to do?
Posted on Dec 18, 2009
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Hi. there is an alignment problem with my canon pixma ip90 printer. I haven't used it for years and finally decided to take it out. changed the ink cartridges, and the alignment problem started. Please...
Go to Control panel. Click on Printer and Faxes. Right click on your printer icon. Click on Properties on the drop don menu. In the properties click on Maintenance Tab. Click on print-head alignment on the drop down menu/tab. Check the printed page after the alignment is completed. If not OK carry it on again till you get the right print.
Aug 20, 2011 | Canon PIXMA iP90 InkJet Printer
Canon pixma mp530 not printing colour. The cartridges are new, when I print an alignment, no colour prints, only the black and white. I've performed a clean, deep clean, print head alignment, nozzle...
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
Jun 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
How do you align cartridge head???
You align the print head like that :
1.go to printer and faxes
2.rigth click on the printer
3.properties
4.then you go on maintenance and pick print head alignment
If i have been useful please give me a vote :).Thanks
Apr 06, 2011 | Canon PIXMA MP460 All-In-One InkJet...
How do I do an alignment test
Click on Start - Printer and Faxes - Right click on the Canon printer - click Properties - click on Maintenance tab - then Print head Alignment. The printer will then print a page with a series of color bars. Note the clearest color print of each color and enter that number when instructed.
Dec 28, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Mar 18, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
Banding
Unfortunately, one choice Canon made to keep the price low was to eliminate automatic alignment. That means you have to align the print heads manually—an unusual step for all but the least-expensive printers today. Manual alignment involves printing an alignment page, picking the best-looking choices for each of several alignment samples, and then entering the settings in the printer driver.
Feb 15, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I need ot manually align my printer head and i don't know how
Please click the below mentioned link to download a word document containing the steps to align printer manually:
Align Print Head manually
Thank you
Jan 02, 2009 | Canon PIXMA iP8500 InkJet Photo Printer
57 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
