Question about Sony Televison & Video
Sony Bravia KDL-52XBR4 has developed thin vertical green lines evenly spaced apart about 3/4 of an inch across the whole screen on all inputs except pc. where I don't notice them.
Posted by Thomas Bleichert on
5 Related Answers
Anonymous
  • 137 Answers
SOURCE: thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Posted on Dec 06, 2007
John Laur
SOURCE: even spaced vertical lines across the whole screen on all sources
If you are handy with SMT rework it might be possible to fix this problem. The heat spreaders on the LCD drivers are insufficient to cool the chips and they will get hot enough to reflow the solder and cause a short on some of the pins. I think it most often happens after bulb replacement since bulbs near their end of life are dimmed and run cooler. After replacing the bulb the bit of extra heat is all that is needed to push them over the edge.
The problem also seems to be most prevalent on the green IC since it shares a heatsink with red and has a smaller area to dissapate the heat into.
If you pull the heatsink you will probably be able to see the short with careful inspection. The pitch is very small - 0.6mm but I was able to wick, clean, and reflow one side of my green IC and the problem went away.
I am planning on adding some additional aluminum stock to the heat spreaders with some thermal adhesive to give the chips more cooling.
By the way the very common rattle noise in these projectors is not a fan but the auto iris. You can unplug the iris servo from the mainboard and disable the auto iris in the menu to work around the problem or you can replace the iris servo for about $75, again, if you are handy with that sort of thing.
Posted on Dec 30, 2008
roety
Eric Rotmil
  • 587 Answers
SOURCE: thin vertical line runs across the top of screen
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Oct 24, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: I have a Flat screen
Are the lines all the way across the screen? or just a few? Solid black - or trannslucent?
Like this??
Horizontal drive has either data, voltage, or control problem from the pixel registry circuit......get it serviced before the problem spreads causing further damage.
However, in all likelyhood, the panel itself is bad. The Bravia line has had a bad rap about the faulty displays, and at $1800 replacement (plus labor) - it may be time to call SONY direct to complain!
Thanks!!
nc
Posted on Apr 02, 2010
Anonymous
SOURCE: Sony kdl-v40xbr1 has horizontal lines
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
Posted on Sep 24, 2010
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Vertical shadows every 3" on sony bravia 32 about 1/4" wide
Image burn from leaving it on.. Its the vertical colors we get when we disconnect everything.. Its stand by screen.. It won't get worse.. But u either have to replace it.. Or live with it..
Feb 06, 2018 | Sony BRAVIA KDL-32S2010 32 in. LCD...
52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
Jun 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Thin vertical line runs across the top of screen on my Sony Bravia KDL-32L4000
I will reply asap
Thanks
Oct 24, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
A green stripe is down the center of our screen.
If the line is present in all inputs and modes(including menu) and is a thin vertical line, then there is a problem with the LCD panel.
The only way to fix is to replace the whole LCD panel. The part is very expensive (depends on which part of the serial number sequencing for your model but will cost at least $1000) and the TV needs to be completely taken apart to replace this part.
Oct 07, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony Bravia KDL-40S2000 thin vertical line
If the line is present in all inputs and modes, there is a problem with the LCD Panel. The only way to fix it is to replace the whole LCD Panel which is very expensive (usually around $1000+ for 40" Sony). Unless the TV in under warranty, it is usually around the same price for a new TV.
Oct 05, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Vertical colour lines on whole screen
The problem is that the panel has failed. Apparently this is a common problem with LCD TV's between 18 mths and 3 yrs old. If it survives over 3 yrs it is likely to last for a few years longer. The cost of replacing the panel is more than a replacement TV!
May 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have a Sony Bravia KDL-32v2500, 16 months old, a thin vertical green line has appeared just off centre. It is on all channels and all input sources. Any suggestions?
If it still under warranty, no cost will be there, but if its out of warranty, you have to pay to Sony (might be they give you some discount) because its problem in LCD Panel.
Aug 05, 2008 | Televison & Video
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
