Question about Lowrance Boating
Does lowrance make a transducer that shoots through aluminum
Posted by Casey st romain on
5 Related Answers
CMV9
Cameron Viseth
  • 594 Answers
SOURCE: When turning on the Lowrance
here is the link to your the lowrance web site. the trouble shooting guide says that if you tried to it on another boat than you might need to take it in for service. but there is a section that explains how to do a soft reset on the unit. you might try that.
http://www.lowrance.com/en/Support/Troubleshooting-Guide/Depth-Reading/
please rate and comment on your experiance with fixya.
Posted on Aug 15, 2008
Editor925
Dean
  • 285 Answers
SOURCE: Lowrance LMS522c transducer
Probably not. Usually the transducer is made specifically for the head unit it is designed for. More often than not, transducers are not interchangeable, particularly across brands. Also, for best results, you really want to install the transducer that came with your new lowrance. That will give you the best results and sonar clarity.
Hope that helps!
Please rate my solution on FixYa!
Posted on Mar 29, 2009
fishdoctorfi
Shannon Currie
  • 178 Answers
SOURCE: Can I use my existing transducer(1000 watt tilted
As long as the connection is the same.....maybe. The difference will be the angle of beam from boat to bottom. May not cover the same area...or you could loose zoom etc. something will be different.
Posted on Dec 27, 2009
GetMeOttaHere
  • 2926 Answers
SOURCE: my fishfinder lowrance x85 the
It is not the transducer. the transducer just provides the sonar reading back to the display. The issue is with the display head unit. Have you tried to adjust the contrast for the fading? Does the screen disappear after awhile? Is the head unit mounted close to other navigation equipment, such as a Compass that may cause interference?
Posted on Jul 24, 2010
Editor925
Dean
  • 285 Answers
SOURCE: How does my Lowrance HDS-5
To connect a LRA 2400 to a Lowrance HDS-5 sounder/chartplotter, you can run an ethernet RJ45 cable from your Radar Processing box to the HDS-5 unit. You will need an adaptor cable for the RJ 45 cable to hook into the HDS-5 head unit. This is part no 000-0127-56.
As for the different transducer pinouts, I am not sure what transducer you have now so I cannot say if there is any kind of converter plug available, however, the HDS-5 units do seem to run best using the transducers that are made for them. Your best option may be to buy the transducer that is made for them, and this will directly connect to the display unit.
Hope that helps!
Posted on Mar 11, 2011
When turning on the Lowrance the depth indicator will only register 0.0 and continues flashing the number. The Lowrance is a LCX-17M. We tryed the Lowrance on another boat with a working transducer...
Aug 15, 2008 | Lowrance LCX-18C
Does the x510c have a speed and temp transducer or just the paddle seperately
Hi Rick
There is only one transducer. for speed/temperature. From page 2 of the owner's manual (see link below)
"A single-frequency with built-in temperature
sensor is packed with the X-510c"
Hope this helps and happy boating!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/X515cDF_X510c_0151-451_120406.pdf
Mar 10, 2015 | Lowrance X510c 5" Screen Color 200 Khz...
How do i install elite 5 dsi on 14' tiller boat
Install the battery cables to the battery for the gas motor.
Here is a transducer installation guide for Lowrance, this is pretty standard for all transducers. Pay attention to how the boat sits in the water when trolling for level setting to match in water.
http://primus.lowrance.com/icr/units/HDS%20Installation%20Guide.pdf
If you don't have a PDF reader foxit reader is free.
http://www.foxitsoftware.com/Secure_PDF_Reader/
Apr 13, 2013 | Lowrance Elite-5 DSI Color Combo...
My Lowrance X-51 is not reading the depth sitting still of running . Do I need a new transducer ?
Yes quite possibly... But a few things to try/check first before you go out and get a new transducer...
1. Ensure the transducer is fully submersed below the waterline when floating and when on the plane... try lowering it more if you can.
2. Check the surface of the transducer itself (the underside) pointing down... If there are any minor scratches or scuffs, this can effect its function or performance. Minor scratches or marks can be sanded out with fine wet/dry sandpaper (at least 400 or 800 grit).
3. Isolate any electrical wires running near or next to the transducer cable. Also check connection of cable at head unit, and that the pins etc are clean, free of corrosion and making good contact.
4. Take your head unit to your Lowrance dealer and they may have a transducer there to use to diagnose whether it is indeed the trasnducer or a problem with the head unit.
Jul 31, 2009 | Lowrance Boating
Built in transducer is not picking up/transferring depth to graph
I havew a Minn Kota trolling motor on a Z21 Ranger. Minn Kota has a built in (puck type) transducer on the motor. I have a lowrance 135x on the front. The lowrance will read the temp but will blink the depth. I switched out the depth finder with another 135x with the same results. I have a 522c gps unit networked together and mounted on the console that works fine. Any suggestions on the problem with the 135x?
Jul 27, 2009 | Minn Kota Maxxum 70 Universal Motor/Sonar...
Hope that helps!
Mar 29, 2009 | SI-TEX Boating
Boating Logo
113 people viewed this question
Top Lowrance Boating Experts
Mike
Marvin
Marvin
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
