You know we aren't anything to do with Acer Support? We are Fixya dot com, a self help, peer to peer website.
Your best bet is to get it from Walmart. You can return it in store if incorrect. Or you just order it for the laptop model.
Superer 45W AC Charger Fit for Acer Spin 1 SP111-31 SP111 ...www.amazon.ca > Charger-SP111-31-SP111-31N-SP1...
Superer 45W AC Charger Fit for Acer Spin 1 SP111-31 SP111-31N SP111-32N SP111-33 SP113-31,Swift 1 SF113-31 SF114-31 SF114-32 Laptop Adapter ...
45W AC Charger Fit for Acer Spin 1 SP111-31 SP111-31N ...www.amazon.ca > Charger-SP111-31-SP111-31N-SP1...
45W AC Charger Fit for Acer Spin 1 SP111-31 SP111-31N SP111-32N SP113-31 Laptop Power Supply Adapter with Cord: Amazon.ca: Electronics.
Ablegrid 45W AC Power Adapter Charger for Acer Spin 1 ...www.walmart.ca > Ablegrid-45W-AC-Power-Adapter-...
Buy Ablegrid 45W AC Power Adapter Charger for Acer Spin 1 SP111-31 SP111-31N Laptop Supply from Walmart Canada. Shop for more available online at ...$22.95 · In stock
Superer 45W AC Charger Fit for Acer Spin 1 SP111-31 SP111 ...www.amazon.com > Superer-Replacement-SP111-31-S...
Buy Superer 45W AC Charger Fit for Acer Spin 1 SP111-31 SP111-31N SP111-32N SP111-33 SP113-31 SP111-33-P88 N16W2 N17H2 N16W1 N18H1 ... Rating: 4.5 · 105 reviews
45W AC Charger Replacement for Acer Spin 1 SP111-31 ...www.amazon.com > Superer-Portable-Replacement-SP...
Make sure this fits by entering your model number. · Fit for Acer Spin 1 SP111-31 SP111-31N SP111-32N SP113-31 Laptop · Output:19V 2.37A 45W (Compatible ... Rating: 4.6 · 34 reviews
all I have are questions,
personally id have to see the service tag photo to wax smarter.
the correct place to ask is there EVERY TIME.https://community.acer.com/en/
OP never a said what was wrong about it.
cable too short.
runs too hot. the pack.
PC says wrong pack, BIOS boot error.
PC is dead.
plug on end is dead wrong,
PC will not charge the battery .
PC fails only using 3D mode.
or/// the endless list of symptoms here.
ask here. and win. no country told.
Power packs very by country.
for voltage(pinouts) and wattage's and laws.there. NOT ONE DO I KNOW on yours.
story endless
bob (random name)
Bob lost his power pack in baggage claim. oops (it not a charger the charger is inside PC) it is a DC power pack. raw.
buys one on fleabay (random) fails.
buys on another, fails buys one more on amazon fails.
the wakes up and goes to
finds it needs the higher wattage Pack.
and 4 sizes sold. 3 wrong 1 right.
so goes the game of endless wrong packs
endless stories and pain, on all PC forums.
ask.https://community.acer.com/en/
even the power AC cord end must be right by country, lots more wrong can be.
I will not post wrongs all now. too lazy.
Larry. All your excellent information should be down here with Answers, not Request for more Info. It is better for the site and searchable.
SOURCE: iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
SOURCE: HP Pavillion dv6500 won't charge
Compare voltage and current (amps) from the original to the new. If the new one is different (voltage is lower, or current substantially lower), then it might not be an adequate replacement. If these are near identical, and you have the correct sized tip, there shouldn't be a problem with the new unit. Obviously, you could get an exact replacement supply $$. Also check online for replacements.
SOURCE: Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
SOURCE: Need to replace power cord to battery charger of cordless drill
it takes a 24V DC 200mA The one I have is a Ktec Model KA12D240020034U
SOURCE: acer aspire 5920 wont start. light in AC chrger
This is a sample of what you can try to do to diagnose a non-starting computer, If these don’t work, realize that most likely a system board (motherboard) has failed or the actual power trim strip above the keyboard has failed.
If it does not, there are 2 possible things I would suspect the Control strip or the mainboard. If you don't get the computer to start back up please put it back together so you remember where all the screws go. Even if you plan to get another mainboard put it back together.
did you ask here first,
only they can help, ask them.https://community.acer.com/en/
the part you want varies by country and other factors, even OPTIONS new chosen.
did you?
the reason it is wrong is you did not ask acer to help you, we are NOT THEM.
they also do not publish parts list like beloved Dell and HP does. (acer = pain)
the real list they did not publish is the power packs offered new for up to 4 option variants, sold day1.
if lost?> , buy the higher wattage pack for the series, and IT WILL WORK.
