Question about Solar Electronics - Others
How to program the wanderer rs232 solar charger controller
Posted by Dwight cooper on
How long does it take to charge battery in solar fence charger?
    1. A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.
      About Fence Chargers - Zareba Systems
      www.zarebasystems.com/learning-center/all-about/fence-chargers
    Feedback
  1. About Fence Chargers - Zareba Systems
    A solar powered electric fence energizer usually contains a battery for energy storage. The solar panel collects the energy from the sun and charges the battery. Lead acid batteries, which are used in solar fence chargers, typically last around 3 years, or around 1,000 days of charging.‎What can I do to prevent ... - ‎What factors should I consider ...
    [PDF]Fence Controller Installation - Zareba Systems
Jan 01, 2016 | Cars & Trucks
Tip
Take A Solar Battery Charger with you on your next road trip
We all had a circumstance where we went to use a <a href="http://laptopsbattery.co.uk/sony-vgp-bps9b.htm">Sony VGP-BPS9/B battery</a> powered device and it was out of charge with no market and no way to recharge. Those Were the Days old today with the use of a solar battery charger, will never be far from a power source.<br /> Almost everyone these days has a cell phone and made the short load with no way to charge it back up. The solar charger can be used for this specific purpose, and any other devices that have small rechargeable batteries. The meeting of solar <a href="http://laptopsbattery.co.uk/dell-inspiron-1501-battery.htm">Dell Inspiron 1501 Battery</a> chargers are useful for those looking to make a road trip or go camping or long journey together. You'll never have to worry about the nuisance of using long cords to charge these devices again.<br /> The best advantage ofuse solar battery charger is that you never have to use electricity to charge your sales units. It is absolutely free touse forever and draws all its power from the sun. Some solar <a href="http://laptopsbattery.co.uk/apple-a1078.htm">A1078 battery</a> chargers can also derive energy from a few lamps and bulbs! Using a solar battery charger on a battery charger standard over the years you will save money and allow you to spend that money on other things you deserve.<br /> Using a <a href="http://www.portable-solar-charger.com/">solar battery charger</a> or any other unit Solar energy is also very useful for the environment. Energy conservation is a top priority in today's world and solar energy is a renewable energy source in which we can all do our part to help save the earth.<br /> Keep in mind that solar powered chargers can be used for much more than mobile phones. Recent technologies have made great improvements in the adapters and connectors that you can plug anything with rechargeable batteries to the solar unit. Solar <a href="http://www.battery-mag.us/dell-latitude-d830.htm">Dell latitude d830 battery</a> charger is another great invention to help make life a little easier.<br /> With it you can never be connected to a charger again. You can literally take it anywhere and the price you pay for solar <a href="http://www.battery-mag.co.uk/hp-pavilion-dv6000.html">HP Pavilion DV6000 battery</a> charger will more than pay for itself with money saved in electricity consumption over the years. Free yourself from ever use charging wall again and buy a solar battery charger, today!
on Nov 10, 2010 | Computers & Internet
Bell + Howell Solar portable keychain Charger
Please elaborate. What exactly is your question? : )
Jun 04, 2014 | As Seen On TV Bell Howell Solar Charger...
Unit does not light up
Check the input voltage terminals for power from your array. if there is no power at the input terminals, remove the wires from the controller and check for voltage again on the input wires. If there is still nothing, trace them back and keep checking each connection all the way to the panels. May be a bad connection or wiring. If you have input to the controller, it is being grounded for some reason or the circuit is open. Look for a fuse or reset on the controller. The controller its self may be bad.
Dec 22, 2013 | Morningstar ProStar PS-15M-48V, 15 Amp 48...
Are solar chargers heavier than regular chargers?
Naturally due to the size of solar chargers they are going to be a little heavier than a regular charger, but keep in mind that solar chargers are able to charge you device so long as the sun is up.
Oct 14, 2013 | Electronics - Others
Solar Charge Controller should be giving 5amps but only getting 1.5 amps. Please assist
The charge controller is not designed to absorb power it is normally an on or off situation. (sometimes at high speed).
If it was absorbing 3.5A it would go on fire.
I would suggest checking the solar array by shorting it while out of circuit this will determine the mpp current of the array within about 3% at a given time, reconect the array back on to the charge regulator (assuming the sun has not suddenly been covered by a cloud).
If the current is dramaticaly lower than the short circuit current then the battery bank may be controlling the amperage volume, If this is the case there may be a number of reasons for this which would require further info.
Sep 19, 2013 | HQRP 10A Solar Charge Power Controller /...
When I place the charger on my 6 volt battery to charge the black handle gets extremely hot, why?
Probably a weak connection. Clean the clamping surface and the battery connection surface and try again.
Nov 23, 2009 | Solar OS6130 Octane Series Wheel Charger...
Electronics - Others Logo
98 people viewed this question
Top Solar Electronics - Others Experts
Sheldon Dedek
john h
ray gallant
Are you a Solar Electronics - Other Expert? Answer questions, earn points and help others
