Question about Pride Health & Beauty
2004 Pride Jet 2 HD One red light is lit but no movement. Has 2 new batteries
Posted by Don Coughlin on
jws1013
  • Pride Master
  • 1,708 Answers
One light flashing means: The batteries need charging or there is a bad connection to the batteries. Check the connections to the batteries. If the connections are good, try charging the batteries.
Posted on Dec 24, 2019
5 Related Answers
Anonymous
  • 32 Answers
SOURCE: no movement, forward or reverse
sounds like it is in neutral, look for a lever on the bottom, rear of the scooter to pull up
Posted on May 07, 2009
my-mobility
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
oregoon
  • 175 Answers
SOURCE: How do I remove the chair from my Pride Mobility
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Posted on Jul 11, 2009
Barry Nixon
  • 103 Answers
SOURCE: red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
Posted on Jul 23, 2009
Anonymous
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Posted on Sep 07, 2009
Have a pride jet 3 wheelchair when the power button is pressed all the battery lights come on steady when u move the joystick u hear a single click and no movement
Sounds like a motor problem. Do you get a flash error code that you can post for a more definitive answer. With no current flash code, you would need to go through all the components, testing with a volt meter. There is a chance you have a bad main controller if there is no flash error code on the joystick. If you have access to a hand held programmer you can read the fault codes stored in the controller. By faulting out the chair you can see which fault code increases in number of times it occurs. Start with the obvious first like load testing the batteries. Move on to checking motor lead resistances (motor/brake checks) and continuity of connections between joystick and controller. You can check controller outputs at the connectors. The Pride Mobility website has a series of good, illustrated troubleshooting manuals. Hope this helps.
Dec 13, 2016 | Pride Health & Beauty
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
New batteries new battery harness still 3 red bars and two yellow bars flashing what else could it be
[PDF]Pride Jet 2 Hd Owner's Manual - Scootaround
www.scootaround.com/.../manuals/pridemobility/Pride%20Jet%202%20...
The symbols below are used throughout this owner's manual and on the power chair to identify ... Jet 2 HD www.pridemobility.com. 3. TABLE OF CONTENTS.
Sep 28, 2015 | Jet 2 HD for 350 lbs, Power Chair,...
New batteries installed, and flashing red lights, continuous, will not move
hi , how many flashing red lights are all of them flashing ?
Regards
Rob
www.gewizrepairs.co.uk
Jul 22, 2015 | Pride Mobility JET ULTRA 3 BLUE POWERCHAIR
How to reset manual brake control and where is it.lights go on( 2 red & 2 green) but jet joy stick is so touchy lights blink and I have to restart it.
If the joystick turns completely off when you try to drive it means the batteries instantly are dropping voltage below the operating capabilities. I have also seen bad connections in the battery wiring harness cause the same thing.
Sep 15, 2014 | Pride Mobility Products New Pride Mobility...
2 yellow lights are lit up
2 yellow and 3 red is code 5 - indicates that there is a problem with your right motor wiring. Check the connections to your right motor.
Apr 04, 2013 | Pride Mobility Products New Pride Mobility...
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
Someone gave us a Jet 7 Power chair and we've replaced the batteries and the fuse. I've checked all connections and everything seems ok. but I'm missing something because I'm still getting 2 flashing red...
Assuming it is a P&G controller (it'll say PG Drives technology on the bottom of the joystick), two flashing lights is a left motor disconnect fault. Check the wiring from and to the left motor for tight connections at all junctions. Unplug and replug them, don't just wiggle test them. This should clear the fault.
Oct 17, 2009 | Pride Mobility Products New Pride Mobility...
Power problem
throttle pot or loose hex nut that holds the actual forward and reverse paddle, may be slipping
Dec 20, 2008 | Pride New Mobility Rally 4 Wheel Scooter
Health & Beauty Logo
119 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
