Question about Pyle Car Audio & Video
How do I get my pyle radio from going back to calibration every time
Posted by ROSALINDA PACHECO on
Anon
  • 1,372 Answers
The most common explanation for why a car's clock reset is suddenly is due to the battery.This can occur if the temperature has been frigid, the car hasn't been run for a while, or you've been messing around with the electronics after the engine was turned off.
Posted on Aug 03, 2020
How to install Pyle radio PLR31MP
remove factory radio ,if you dont have the special tool to do this you can use coat hangers but I perfer using the factory tool sold at wallmart (the cheepest) or autozone push tools into holes on both ends of radio pull radio out. disconect wireing harnes and antenna wire.To install new radio you will need a wireing adaptor and a install kit. These must be spasific to your vehicle. you can buy these online Ebay , or Amazon or off line wallmart or orillys auto parts you will have to connect your new radio wiring harness to wiring adaptor.put install kit on new radio attach antenna wire connect wireing adaptor to original radio wiring push radio gently back into dash with install kit attached. enjoy your new radio. if this was helpful please leave good feed back.
Jan 03, 2015 | 1998 Ford Ranger
How to set the time on a pyle plcd11mrkt marine radio?
Click "Download manual or factory spec sheet", save it to your documents folder, and see page 9 here... http://www.rocktheboatmarinestereo.com/html/67460.html
Jul 16, 2014 | Pyle Audio Players & Recorders
When i turn on the car the radio doesnt go to the home page it goes to a screen with circle and arrows number 1234
You have the unit wired wrong. When you shut your key off the radio loses ALL power and it needs ACC power to maintain the memory. If not, the unit will reset itself. The screen you see is the touchscreen calibration screen. Just follow the " X " around the screen to 5. Then the unit will boot up again. You will have to reset radio stations and EQ and speaker settings. If you don't fix the ACC wire, you will have to do this A LOT!
Dec 06, 2013 | PYLE Audio PYLE PLDNV695 6.95 DOUBLE-DIN...
No maps on pyle plbt74g
Hi i so happen to have the sd card maps for this pyle i have the same dvd radio in my truck if your interested let me know [email protected]
Feb 21, 2013 | Pyle PLBT74G Car Video Player
Pyle PLTAB8 Car Component System, Lights will not turn off. Help
Sounds like he did not wire a remote line from your radio to the amplifier, if he put a 12v from the battery to the amp and the remote spot on the amp then it will not turn off, you will need to either wore a toggle switch to the remote so you can turn it off manually or check the back of your radio for a remote line or splice a remote line from the accessory power supply on your radio so the amp will turn on when the radio is on
Feb 06, 2012 | Pyle PLTAB8 Car Component System
I am installing a Pyle PLMR87WB stereo into a Pyle PLMRCW3 Water resistant stereo housing. I am soldering the connectors and shrink wrapping them. Do I need to connect the memory wire. I do not want to run...
OK, time to go into cheat mode. You can always install a toggle switch to that wire. The only features I see you losing are that the time will be incorrect on the clock and it might not save your preset radio stations. All other functions are basic. Might I suggest a lighted toggle switch, this will help to remind you to turn it off.
Happy Wiring
Aug 13, 2011 | Pyle Car Audio & Video
PARTS
Pyle does not sell parts for their units. What kind of part is it? You might be able to find a generic replacement...
Oct 15, 2007 | Pyle PLBINDV7 Car DVD Player
Car Audio & Video Logo
109 people viewed this question
Top Pyle Car Audio & Video Experts
Jeffrey Turcotte
Jeffrey Turcotte
Anthony Ward
Anthony Ward
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
