Question about Music
No sound output from p-85 piano - Music
2 Suggested Answers
Anonymous
SOURCE:
Fred Yearian
  • 5603 Answers
SOURCE: i have a concert 2500...and
The power amp driving the dead speaker has gone bad or if you are lucky only a cable has fallen off. Open and inspect unit.
Posted on Mar 05, 2011
My yamaha piano PSR S750 HAS A SOUND PROBLEM AND THERE IS NO SOUND AT ALL BUT IT COMES ON AND DISPLAYS WELL. WHAT SHOULD I DO.
Check output via headhones - if that works try connecting outputs to amplifier i if that works.
Hold down highest sounding key whilst turning on, this initiates a factory reset. If still no sound open up check speakers are connected, if still no sound then suspect the amplifier has failed.
Feb 28, 2018 | Yamaha Music
Yamaha p-85 digital piano no sound
if there is display and all funtions working check audion IC and replace
Dec 20, 2016 | Yamaha Music
I have baby grand electronic Viscount piano. Power is on with lighted screen but no sound when hit keystroke
Can you activate various other controls?? If so, it sounds like your output amp section might be at fault....Does it have a headphone jack?? If so do it work?? And would really need the exact model number......
Nov 16, 2014 | Music
Yamaha piano
Either a faulty power supply or more likely a damaged socket
Aug 23, 2014 | Yamaha P-85 Contemporary Digital Piano
What is the correct procedure for resetting Yamaha P 85 Digital Pian?
Resetting Instructions:
1) Try a partial reset by holding down the last white key while turning the unit ON.
2) If you haven't recorded any performance(s), for a full reset, hold down on the last white key AND THE lst three black keys while turning the unit ON.
Jan 03, 2014 | Yamaha P85 88Key Portable Digital Piano
Crackling speaker as soon as i switch on my digital piano
It looks like the Korg c-15s has a internally mounted speaker and so I will assume that the speaker and amplifier are part of the piano base. It sounds like either the speaker is blown (crackling sounds heard as deformed voice coil scrapes the magnet structure) or the audio amplifier is distorting the audio.
Connect the piano's output to an external amplifier and speaker to properly identify problem.
Oct 17, 2012 | Korg Music
Yamaha CP33 Studio Piano won' turn on. Was thinking maybe the power chord overheated but really have no idea
Make sure you have the CORRECT adapter for the unit. It should say Yamaha on it and match the voltage and polarity. Thest the output with a meter. Common problems that happen to the piano itself causing the symptoms is a broken power connector or broken solder at the connector. Use a meter and verify the adapter is producing output. Expect the output to be a bot higher than listed when not plugged into the piano as there is no load on the adapter.
Apr 29, 2011 | Yamaha CP33 Digital Stage Piano (Warehouse...
Yamaha P-200 electric piano does not have any
Plug in your ear phones to see if you can hear the sound that way. If not you are experiencing some internal failure in your integrated amp output.
In that case you will need to get authorised service.
Oct 06, 2009 | Yamaha Full-Size Keyboard
Music Logo
52 people viewed this question
Top Music Experts
Michial Gueffroy
Marvin
Marvin
Are you a Music Expert? Answer questions, earn points and help others
