SOURCE: Paper jam in HP 4255 office jet all in one printer
Clearing paper jams
Paper jams can be real or false. The unit may report a paper jam even when there is no jammed paper. The solution to a real paper jam or a false paper jam is the same.
CAUTION:
Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit.
Figure 2: Removing the rear access door
Preventing paper jams
The following information will help prevent paper jams from occurring:
SOURCE: Paper Jam detected. None found.
Here is the Xerox support page for your printer. It even has a movie on removing paper jams.
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8400&country=United%20States&language=en#_manuals_and_documentation_
SOURCE: back cover open message on brother mfc 7820n
Had same problem. Closer inspection revealed bit of paper out of sight. Removed the toner cartridge and worked to free torn paper. Then restart. Hope it helps.
SOURCE: MX860 error message reads: ''Rear cover - The
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you.
Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I got a paper jam. I can not get to the paper. I s...
I removed the cartridge, pulled out the skewed paper and it ripped leaving a very small piece behind. This continued the notice 'paper jam'. I had to remove the two side springs, remove the two star headed screws nearby the springs and prise up the grill to remove the paper shred. Replace everything and the error message is gone and printer normal.
