Question about Toshiba Televison & Video
I have a toshiba 50l1350u tv that turns off and on with the side button, but only turns off, not on, with the remote. Is that a defective ir sensor? I don't have the original remote, but have tried a uverse remote, all the codes. Two different codes work but no power on. I have also tried several remotes available in the play store using my phone that has it out and same thing. Everything but power on works.
Anonymous
SOURCE: Toshiba remote
i need code for my tv is toshiba color cf32 H40-86486130
tac 9806
ac 120v 60 hz
agos 1998
Posted on Apr 05, 2008
Why won't it turn on?
Fairly new TV will not turn on. - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions/Fairly...TV-will-not-turn-on/.../27334...
Feb 29, 2012 - My Toshiba 32dt2u1 television that I got this past Christmas will not turn on at all. I press the power button and it nothing happens. The green. Tv no power: Model 50L1350U
Jun 20, 2014
My laptop won't turn on!!!
Feb 19, 2014
40RV525U Toshiba LCD TV won't turn on.
Nov 22, 2011
55HT1U turns on by itself, wont stay off
Sep 19, 2011
More results from forums.toshiba.com
Questions & Answers for LCD TVs - Toshiba
answers.toshiba.com/answers/0293/category/...tvs.../questions.htm?...
Is my TV compatible with netflix? ... How do I reset my 32C120U tv so I can perform another channel scan? .... My tv won't turn on with remote or manually.
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
Jan 08, 2016 | Toshiba Televison & Video
Toshiba tv 40rv525u has started to change channels
My TV 40RV525U changing channels, menus itself for few months ( I use antenna).
my son tried to stop the channel scrolling by enter weird number into the channel to stop it scrolling such as 555, 777..
later, it turn on off by itself and unable to hold on a channel
I call Toshiba customer service and they ask money $25 for troubleshooting but I denied since I do not want to waste money and time.
Now, I found how to fix it myself.
In my case, something was wrong with the signal comes from the button control on the left side of the TV.
What I did
unplug the power cord.
Remove back cover.
Look into the motherboard ( biggest green at the center).
First, I disconnect a connector on the motherboard come from the IR board that receive the wireless signal control ( meaning the remote is disable).
I turn on the TV, press on Menu button on the TV side. Menu is still scrolling.
I turn off TV, disconnect power cord and connect the IR connector back to the motherboard.
I then disconnect the nearby connector that comes from the side control buttons.
Turn on the TV by remote, press menu button on the remote to check. The menu stays.
DONE.
I use electric tape to seal off the connector and let it hanging there.
Close the TV back panel
I have been watching TV for 3 nights without menus/channels scrolling.
NO AVAILABLE red message when watching DVD is no longer existed.
Hope this help someone else.
Jan 20, 2012 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 26AV600T When turn off by remote control ( stand by lamp still illuminate) I can not turn on by remote ( ON/OFF in the same button ) Q: TV set OR remote is bad. Thank you /// Thongsuk. My Mail:...
Tries the tv manual control power button pushes a couple of times on/off,if tv it turn on and off with no problems.Yes.Than the tv remote have problems.Try Remotes.com to buy the original remote.
Jul 13, 2011 | Toshiba 26AV502U 26 in. LCD HDTV
Hi! My Toshiba 40RV525u TV has a problem, it turns off or on by itself. I checked the auto power off settings, the time is not set (it is 00:00). This happens very randomly. Now I just plug out in the...
My TV 40RV525U changing channels, menus itself for few months.
later, it turn on off by itself and unable to hold on a channel ( I use antenna)
What I did
Remove back cover.
DONE.
Jan 14, 2011 | Toshiba 40RV525U 40 in. LCD TV
Toshiba 40rv525r screen says NOT AVAILABLE
I've had the same issue! This is caused by the control panel telling the TV what to do - does it change channels on its own, too, or turn off or on on its own?
What you need to do (if you've not already done it) is lock the control panel out, which you can do under the LOCK menu.
What may help is running the factory reset on page 54.
Mar 22, 2010 | Toshiba 40RV525U 40 in. LCD TV
I have a 32AF43 remote has stopped working
resolder the ir sender it sound like it the solder has broken free
Jun 23, 2009 | Toshiba 36AF42 36" TV
Remote will not function with TV
If two remotes do not work. I would say the IR sensor on the front panel of the TV might be defective.
Can you provide an exact TV model number to try to locate an IR sensor part suppier?
Mar 10, 2008 | Toshiba 36A43 36" TV
Televison & Video Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
