SOURCE: air compressor will not run. motor will try to start but trips
If you're running it on an extension chord they tend to do that, especially if they're really cold or really hot. If that's not it you could try changing the oil, or just check to make sure that's full. Keep in mind really cold oil will work just like it does in your car. Try that and see if it helps.
SOURCE: we have a rotary screw IR compressor 50hp with
when does it shut down and what is the temp and pressure when it goes down.
SOURCE: I have a Clarke SHHH air 2/9 compressor
I also have a Clarke SHHH 2/9 with the same problem. I sent it off to machine mart service dept. in Nottingham who quoted £189 to replace a faulty pump. Am not going ahead with repair since replacement cost is only £250. Cost sending to Nottingham (from local machine mart) & cost of estimate & cost of return (to local machine mart) was £24 which I thought was reasonable. Very unimpressed with compressor itself wich failed after only light use.
SOURCE: We have IR SSR 150HP compressor, where when
to change rotaion on a three phase motor just which 2 leads.
Change L1 to the wire now on L2 and take the wire on L2 and move it to L1. the rotation will now change. or L2 and L3... just two wires
