Question about Radio Shack Radio Communications
Radio shack pro-508 squelch do not work - Radio Shack Radio Communications
Posted by Scottie Thompson on
Anon
  • 1,433 Answers
I think that google could have video's about what to do and how to fix your pro 508 squelch from Radio Shack.
Posted on Aug 06, 2020
4 Related Answers
Anonymous
SOURCE: NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
[email protected]
Posted on Aug 28, 2008
JOHN BABA
  • 1274 Answers
SOURCE: constant squelch noise
turn the squelch till silent
Posted on Feb 15, 2010
Anonymous
SOURCE: Radio Shack Pro-508. The lock out key and program
Need to do a hard reset, turn power off, then back on. Hold down [CLEAR], press the reset button on the back then release [CLEAR]. I found it in the manual for the Pro-2018.
Posted on Sep 13, 2010
Anonymous
  • 88 Answers
SOURCE: need an replacement antenna for
Hi.
Check on eBay. You need a standard BNC connector antenna for this scanner. Radio Shack scanners are made by Uniden so a Uniden BNC antenna will fit your unit.
Here's a link for an antenna on eBay:
http://cgi.ebay.com/UNIDEN-DESKTOP-SCANNER-ANTENNA-BNC-SCAN-3-/220734104369?pt=LH_DefaultDomain_0&hash=item3364c72331
Posted on Feb 09, 2011
Need an replacement antenna for my radio shack pro-508 scanner. Radio shack does not carry them anymore
Hi.
Feb 08, 2011 | Radio Shack Pro-2018 Scanner
Need an antennea that is for pro 508 scanner
The screw-in antenna for your scanner is Radio Shack Catalog number 10538353. You should be able to purchase one, or order one, from your local Radio Shack. Also check eBay - but make sure that it's the correct antenna for you scanner. Not all screw-in antennas have the same thread size. Check prices closely. Considering the age and limited capability of your scanner, you might be better off purchasing a new or used scanner rather than an antenna for the 508.
Bill B
Jun 05, 2010 | Radio Shack Pro-2018 Scanner
Have a Radio Shack PRO 2018 that stopped working properly,Scans but necver finds anything.adjust squelch and nothing but static so it is not the speaker.PLEASE HELP
Did your local public service switch to a digital system? If so, you cannot receive digital trunking on this radio. Ask at your local Radio Shack store, or a local ham radio operator who can help you out.
Jan 12, 2010 | Radio Shack Pro-2018 Scanner
Oct 17, 2009 | Radio Shack Pro-2018 Scanner
My Pro 96 does not come out of Squelch mode on any channels
Are you hearing any communications at all? Sounds to me like someone has programmed the ctcss tones for each frequency. Try programming a frequency without a tone and you should get a squelch. If not then you probably have to return to the repair shop. GOOD LUCK.
Apr 13, 2009 | Radio Shack Pro-96 Scanner
Scanner will not move from the programmed Police channel
you may need to play with the squelch. and/also hold down the light/key button until the key goes away but mess with the squelch after you get rid of the lock. you want the squelch as far left without it stopping and making static noise
Jan 18, 2009 | Radio Shack Pro-82 Scanner
NO SQUELCH
Sincerely
Greg Stevens
e-mail
[email protected]
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Communications Logo
96 people viewed this question
Top Radio Shack Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
