Question about Casio Office Equipment & Supplies
Casio print calculator:the paper feed button does not advance the paper even though i am sure that i have inserted the paper correctly - therefore i get overlapping numbers-please advise
Posted by DAVID EZRA on
5 Related Answers
Anonymous
SOURCE: casio DR-T220
Turns out the incorrect type of paper was being used. The paper needed is the paper that is sensitive to pressure and this paper was not.
Posted on Jul 22, 2008
Anonymous
SOURCE: Loading Paper into a Casio Calculator
This isn't too complicated. And for the lazy guy that just put a phone number for the fix, what the heck do we need FixYa for anyway? :\ For cryin' out loud! :) )
1. Slide the clear plastic cover toward the back to remove and flip of the metal spool holder up. Place the roll of paper on the holder. (Make sure the paper drops off the "back" of the spool for proper feed.)
2. Feed the paper into the bottom slot at the **** end of the calculator.
3. Feed the paper through that bottom slot along the inside case under the black guide inside. If you tilt the calculator correctly, you can look inside and see there is a way to slide the paper under the guide.
4. Making sure the paper slides as far as it can, press the FEED button until the paper starts feeding.
5. Feed enough paper to slide through the clear plastic cover and you're all set.
This isn't factory, it's just what I figured out playing with the thing. If you can think of a better way of explaining the procedure, by all means edit this and post!
God bless!!
Maridian
Posted on Nov 14, 2008
Anonymous
SOURCE: Loading paper
Cut paper at an angle and insert and push into back slot with tip of angle (apex) to the right of machine when facing it. It should engage number wheel when you hit addition sign, You may need tweezers to pull it thru if it doesn't advance.
Posted on Jan 23, 2009
Anonymous
5/14/09-
Okay...It took me forever to figure it out but I finally got it. On the back of the calculator there is a slot (back meaning where the black cord is connected to the calculator). fold the paper to make a perfect straight line. feed the paper through there and press thee upward arrow. it should work.
hope I helped...=)
Posted on May 14, 2009
Anonymous
SOURCE: loading paper tape
Well, I just had a long and vigerous fight withmy new HR-8TM. I came here and read all the before mentioned solutions. Then the idear struck me. Instead of cutting the paper even all the way across the roll, I cut it slanted on the sides and straight across the middle " __ " and guess what it passed the roller feed through.
It worked for me, maybe it will work for you.
Posted on Feb 14, 2010
How do i feed the paper of the casio fr 2500 printing calculator
Hello Michel Dekock,
Could not find your FR2500 (but close)...
Has worked every time for me...
Mount the paper roll on the wire bracket... feeding
over the top of the ROLL (TOWARD THE MACHINE).
With the keyboard FACING away from yourself
Fold the FRONT EDGE of the PAPER on to the
side to form a chisel point... and insert the point
(folded side up) in the rear roller slot (paper feed)...
As shown on FR2650
http://www.ebay.com/itm/Casio-FR2650TM-Printing-Calculator-FR2650TM-/122298781152?hash=item1c79934de0:g:bwEAAOSw44BYbWjv
With the PRINT feature turned on the roll should be
advancing while holding down the TOTAL key...
Hold the key until the edge of the paper roll emerges from the machine.
Hope that helps.
(now you only have to freshen up the ink).
https://en.wikipedia.org/wiki/Carnac_the_Magnificent%E2%80%8B
Mar 27, 2017 | Casio Office Equipment & Supplies
How to install paper
Without a manual, look at the picture of the calculator. Mount the paper, with the feed coming forward and over the top of the calculator. Insert the paper (recommend cutting it flush) into the feed slot in the back. Then use the paper advance key to advance the paper through the rollers. Unfortunately the manual is not available from the Staples website. Good Luck,
Mar 02, 2015 | Staples SPL-P100 Printing Calculator
Need to know how to insert printing tape into Canon P23-DH color printing calculator?
Install paper roll with end coming up from rear. Insert end of paper into slot at back of calculator until it stops. Then press feed button until paper advance thru slop at top.
Jul 17, 2010 | Canon P23-DH Calculator
I have a PCR-T2000. Even though the receipt button is on the receipt paper roll on the left will not feed.
I have never had this problem. Try pressing POST RECEIPT after the sale to make sure it is not in paper save mode. If it still doesn't work, make sure your paper is the correct width (57mm). If it is narrow, the paper sensor will not detect the roll. Make sure it is clamped correctly under the paper holder. ----------------------------------------------------------------------------------------------------
If anyone needs a Casio PCR-T2000 manual go here: http://the-checkout-tech.com/manuals/cashregisters/Casio2.php
May 19, 2010 | Casio Parts Cash Register PC Desktop
I have a borrowed Casio FR 105S printing calculator. How do I load the paper?
Make sure the paper has a straight clean edge. Feed the paper into the slot in the back - make sure the paper is straight. Paper will go in about 1/4 inch. Push the feed button and the paper should feed through the printer.
Feb 05, 2010 | Casio HR-8TMPlus Calculator
HOW TO INSTALL PAPER ROLL IN CASIO HR-8TM
There is a slot just in front of the printer
1. turn the power on
2. turn the switch to "PRINT" position
3. slot the paper in & press "FEED"
4. the paper should be able to feed up
Jul 18, 2009 | Casio FR-2650A Calculator
How to load the paper into casio hr 100T . My son just came home with this old model. It has paper provided but no instructions. How do we get the paper to feed and in what directions does it need to be...
I have a casio HR-100 TM. After spending over an hour, and scouring the casio website which had an obscure spot that covered a totally different calculator!.... I found a slot in the back of the machine that when I folded the paper into an arrow, FINALLY went in! You may have to try a few times, but it will go in just keep holding down the feed button as you push and jiggle the paper.
Jun 20, 2009 | Canon P1-DHV Calculator
Cannot load new paper roll into the calculator so it catches
Replacing the paper roll involves feeding the evenly cut, uniform end of the roll through the fine slot located under the paper arm at the back of the calculator. (Even if the paper is only slightly wrinkled or cut unevenly, it will not feed through the teeth in the loading area.)
When getting ready to feed the paper into the calculator, envision your printout feeding out of the machine away from you and back toward the paper roll. Don't insert it upside down.
To get the paper feeding through once you have partially fed it into the teeth, gently tap the paper feed button. Once or twice should do it. (The button is located on the far top left of the control panel, indicated by an arrow jagged saw mark icon).
Then, slide the paper roll onto the feeder arm and you're in business.
Apr 09, 2009 | Sharp EL-1801C Calculator
Loading paper
5/14/09-
hope I helped...=)
Aug 15, 2007 | Canon P23-DH Calculator
Loading paper
Hi, I had the same problem...but I fixed it. Here's how: At the very back of the calculater under the paper roller there is a very thin horizontal slot. Insert the tip of the paper roll into the slot, then press the paper advance button located on the top left hand sidw of the calculator until you see the paper. Guide the paper through the top slot and voila.
Mar 28, 2007 | Canon P23-DH Calculator
Top Casio Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Carlo Barzo
Carlo Barzo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
