Question about Exercise & Fitness
Miconic B Schindler lift, "Stoer" error on the card. What can be problem? It is running sometimes and suddenly stop with "Stoer" error on the upper level.
Posted by Uyangulov Alexey on
Andrew Taylor
    Top Expert:
  • Exercise & F... Master
  • 33,991 Answers
Contact your elevator service company. You can't work on it yourself. Seems to be serviced by KONE.
https://elevation.fandom.com/wiki/Schindler_Miconic_Controls
https://parts.kone.com/Products/KM51321569
https://translate.google.ca/?hl=en&tab=rT#view=home&op=translate&sl=auto&tl=en&text=stoer
It may just be telling you the ceiling fan is on, OR, it needs cooling.
Posted on Aug 06, 2020
2 Related Answers
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Schindler miconic v lift suddenly power off just mili second and then restart. what is the problem? please solution this
You have this posted inthe car and truck problem section. Please re-post.
Posted on Jun 12, 2012
AJIN G
Electro Med Services
  • 6694 Answers
SOURCE: What is the error 75 for elevator? HYUNDAI ELEVATOR Type STVF 7 How to solve this problem? Lift suddenly can stop any floor as not level. Thanks
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Posted on May 19, 2016
Troubleshooting
error code problem E020 ,0173
Aug 15, 2013 | Fargo DTC400 ID Card Printer Package
Error 42 on a precor treadmill
Precor Error Code 42 Error Code: 42 Manufacturer: Precor
Model: All Models
Error Description: Error 42, Lift Position Value Out of Range. Error 42 is displayed when the lift position reported by the lift position potentiometer is found to be outside its set limits.
If an Error 42 has occurred, it is important to know the physical position of the lift when the error occurred. It is possible the lift is physically out of range or jammed. In this case, the Error 42 is a secondary symptom and the issue should be approached as an Error 40. Possible Reason:
  1. Bad or intermittent connection in the lift motor controller.
  2. The lift motor requires calibration.
  3. The lift motor potentiometer is bad.
  4. The lower PCA to upper PCA cable is bad.
  5. The lower PCA is bad.
  6. The upper PCA is bad.
Recommended Action:
  1. Intermittent connections can be difficult to locate. If the Error 42 condition is intermittent, a connection issue is probably the cause. This is definitely true if the Error 42 occurred while the lift was within its normal physical range. Inspect the lift potentiometer connector and repair connection if necessary. If the intermittent connection cannot be found or corrected, replace the lift motor. A lift calibration number of 0 or 255 indicates an open or shorted potentiometer connection. This means the problem could be anywhere between the lift motor and the upper PCA. Typically it can be identified and tracked using an ohmmeter.
  2. Using the appropriate service manual for the unit being tested, refer to the lift calibration procedure. If the information in the service manual doesn't match the lift position/physical lift position of the unit, recalibrate the lift motor. [Something caused the lift motor to be out of calibration. Investigate for cause and correct. Simply recalibrating the lift motor will not solve the problem.]
  3. If the lift calibration number is not 0 or 255 and does not change when the lift motor turns, replace the lift motor.
  4. Check continuity of the interconnect cable or swap with a known good interconnect cable to verify if cable is bad.
  5. Swap the lower PCA with a known good lower PCA to verify if the lower PCA is bad.
  6. Swap the upper PCA with a know good upper PCA to verify if the upper PCA is bad.
Lift Position Value Out of Range Precor Error 42
Sep 13, 2012 | Precor 9.31 Treadmill
My Precor 9.31 has error 42 displayed and will not go away by holding down the QuickStart button;what is the next step?
Model: All Models
Recommended Action:
Dear sir, i have an electric treadmill of apollo brand.Suddenly the belt started jerking and then stopped.It gave an E 02 error. The repair guy came and checked the card and said it was fine.Sometimes it...
This error is coming Because the NOT lube the Walk Belt, try to do it.
However if the error coming again, the Controller Motor Board must be Replace.
Please test the motor if is Running well, LUBE the shaft and see if the Brusher are working good or replace it. Please carefully with the drive bel you must have 1/8" of deflection.
Blessing
[email protected]
cell+whatsApp;;+50588611441
Oct 27, 2017 | Exercise & Fitness
Received err 42 on my Precor EFX 5.21s - what does it mean?
Model: All Models
Recommended Action:
Dec 28, 2010 | Precor EFX 546i Elliptical Version 4
Precor efx 546 error code 42
Model: All Models
Recommended Action:
Nov 30, 2010 | Precor EFX 546i Elliptical Version 4
I bought a second hand 9.21 Treadmill.The machine suddenly stops when I'm running on it. Sometimes after 30 minutes. Sometimes immediately. I had an electricien check the electrical network and that was...
Sounds like the wax lubrication has finally boiled off the belt the easiest way eliminate this problem is to rewax the deck. You may purchase this @ http://www.gympart.com/ or call them 1-800-496-7278 I would recommend what is call WAX BLAST they come in 3oz or 6oz bottles.
Now the fun part to apply this product you must first get the treadmill and walk on it for about 5min to heat up the deck, then stop the unit with your product go to upper third of the belt lift edge of the belt stick the nozzle between the belt and deck squeeze the bottle approx. amount 1 tbs of wax to the center then get back on the treadmill and walk for 10 min this is to heat up the wax so that belt will act like a wick to absorb wax! This should be done every 3 months or so. Their a catch if this does fix the problem you may be investing in a new belt and possible and new deck. Hope this take of it!!
Mar 30, 2010 | Precor 9.21 Treadmill
Error in body
Remove lens, CF card, and battery. Leave in a dry and slightly warm place for 24 hours. Clean lens contacts with a cloth or cue tip and eclipse/alcohol.
If the camera doesn't turn on after this, even without CF card and lens attached, then it needs to go to a Canon service centre. Don't tell them you got it wet, and maybe it will get repaired FOC.
Jul 07, 2008 | Canon EOS-20D Body only Digital Camera
Exercise & Fitness Logo
115 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
