Question about HP Computers & Internet
How do I get my wireless HP mouse to work? - HP Computers & Internet
Posted by Jenna Singleton on
I have a wireless HP 4 button laser mouse NK528AA, model: MORFD7UL. Is there a wireless keyboard that will work with the same dongle?
I'm afraid the the dongle is proprietary and only works with that particular mouse. You can however purchase a separate wireless keyboard and it shouldn't interfere with the mouse.
Jun 18, 2011 | HP Wireless 4-Button Laser Mouse...
My wireless mouse has quit working. I'm guessing I need a new battery. However, I can't figure out how to even find the battery, let alone change it! How do I do that????
Cutting down on the number of wires that must be tolerated in a work station adds to maneuverability and ease of location. For all their convenience, though, wireless accessories bring with them a number of issues not present in their wired counterparts, most significantly battery change.
Instructions
    • 1 Turn off the mouse.
    • 2 Remove the top of the top of the battery compartment. The button that releases it is located toward the rear of the mouse.
    • 3 Remove the old battery and place the new one in its place. Replace the cover and turn the mouse back on.
Read more: How to Replace the Batteries in an HP Wireless Mouse ' eHow.com http://www.ehow.com/how_6947071_replace-batteries-hp-wireless-mouse.html#ixzz1LpG7oNYf
May 09, 2011 | HP Wireless Optical Mouse
I have an HP wireless mouse and keyboard, my mouse suddenly stopped working, how can I fix?
It is possible the mouse needs new batteries or needs to be charged.
Try replacing the batteries to see if the mouse starts working.
If that does not work then try re-inserting the wireless receiver into a different USB slot.
Please rate this if you found it useful.
Mar 06, 2011 | HP USB Wireless Keyboard/Optical Mouse...
I have a samsung np-nf110/nf210/nf310 , os is windows 7 starter. i wanted to use my HP wireless optical mobile mouse but it doesn't seem to work or i dont think it connected. batteries are brand new and...
we dont do Samsung here, its HP
but HP mouse with no model stated, is impossible to be accentuate.
its a wireless mouse right, you left only small hint.
battery powered wireless mouse ,.by HP
windows 7
wireless mouse, HP and Samsung.
that takes 2 working drivers to make that work. both HP
the USB side and the mouse side.
HP does not support this on non HP computers so windows 7 is the only hope, MICROSOFT PLUG AN PLAY
you must be connected to the internet or its all just a wasted of time,
do so.
then plug both those things in.
the PC goes Dingdog sound telling you its found a new USB device.called wireless mouse HP, (no model stated)
then tries to find a driver on the web, MS servers for that.
if it can find one, then good luck, doing that. as the HP drivers will not like your PC
as here, if this is possible at all.
https://h30434.www3.hp.com/
Jul 05, 2017 | HP Wireless Optical Mouse
Dear Sir, My optical hp wireless mouse does not select a sentence or paragraph when I left click and drag on the sentence or paragraph to select it. The gray shade of the selection disappears once I...
wireless mouse 101 (no PC stated, no OS stated)
no mouse model stated.
so plug in a wired mouse for $3 and use that, until mr. wireless works?
the wireless needs many things to run right.
1: it's battery now dead. the manual to that covers this.
2: mouse drivers good . from HP if any HP mouse.
load the driver yet. Get them at HP, ever heard of theM>?
3: OS not corrupted, no OS stated, XP? vista, w7/8/10?
4: click CP control panel and set the mouse up like you want it.
there are many mouse controls ,and can be set wrong, simply.
Oct 19, 2017 | HP Wireless Optical Mouse
I purchased a HP laptop, Windows 7. I installed
You have to install the software that came with the wireless mouse. I have several, and some will and others won't work without the software. That is 90% what it is.
May 17, 2010 | Logitech Cordless Mouse
My hp wireless mouse does not work and i cannot sync it to my PC. the wireless keyboard works fine and i am able to sync it. how do i fix my mouse problem?
Remove the battery of the mouse and install new one and then press connect button from the mouse side and the receiver side also.
Nov 25, 2009 | HP Wireless Optical Mouse
Hp wireless mouse not working
HP wireless mouse may not work due to improper connection of the receiver. If unknowingly you connect the receiver to a different port, then it may cause serious issue with HP wireless mouse.
If the connected port is corrupt and if the port is experiencing any problem, then the wireless mouse may not work properly.
In order to resolve this issue, you need to repair the port.
Get more information to fix HP Wireless Mouse Not Working . Hope this information helps you.
Oct 29, 2009 | HP Wireless Optical Mouse
HP wireless mouse
Try replacing the batteries. Wireless mice do funky things when the batteries are low.
May 18, 2009 | HP Wireless Optical Mouse
Computers & Internet Logo
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
