Question about Sharp Televison & Video
I have a 70" Sharp TV LC-70LE660U Serial # 501858230. It has sound but no picture. I took it apart, the backlights come on the cuts right off, do anyone know whats wrong?
Posted by Jamie Barker on
  • Sharp Master
  • 18,438 Answers
The backlight is LED strips. When the television comes on the power supply senses the current draw and shuts down if it is too high. When one led on the strip burns out the current draw increases. You need to replace the LED strips or troubleshoot down to each diode and find the bad one(s)
Posted on Aug 07, 2020
5 Related Answers
Anonymous
SOURCE: LC-37D62U Sharp Aquos HDTV Settings
lost sound on Sharp Aquos 37LCD62U
Posted on Jan 25, 2008
circuitworld
Circuit World
  • 335 Answers
SOURCE: sharp aqous lc 37 in tv power no picture,sound
Your control board seem's defective or the inverter board (associated circuits) are bad. This is common in most TFT-LCD Tv's.......
Posted on Dec 01, 2008
Anonymous
  • 10 Answers
SOURCE: tv comes on but no picture
try unplugging the tv (no electricity what so ever going into the tv) and just let it stand vertically for atleat 24-48hours then plug it in and try it out.
if that easy fix doen't work then you either have a blown fuse or and busted lamp. contact a professional and show them your warranty.
Posted on Mar 01, 2009
Anonymous
  • 1077 Answers
SOURCE: My Sharp TV will only hear sound. No picture or images even from the tv menu setup option. Model# LC-19SB25U. About 1.5 yrs old. Converter box ok.
In most cases, you can reset the TV by leaving it unplugged for 30mins.
If this doesn't work, I believe the circuit board that supplies power to the screen maybe bad. They call this board a backlight inverter board. It would most likely cost more to repair than replace the TV .
Posted on May 27, 2009
Anonymous
  • 1077 Answers
SOURCE: Sharp LC-32SB24U Service manual
Here's one place for you:
http://www.nodevice.com/manual/newmans/upsharp/LC32SB24UPDF/get53755.html
Posted on Sep 04, 2009
Model no. 32A33M LCD sharp tv, 32 inch, of serial no. 804734030. no picture shown. only sound is coming. i can decresing/increasing the volume. what can be the problem .
Do a flashlight test. With the TV on and a program is playing, shine a flashlight on the screen. Can you see movement in the picture? If yes then the backlight drivers are not working. If NOT, then the T-con board is bad You can get parts from here : TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 09, 2014 | Sharp LC-32A33M LCD TV
I have a sharp LC-37D40U that will not power on. The power light blinks 1 time every second. I held the input and volume - button while plugging the TV on and the TV cuts on and then cuts right back off,...
OK if you have blinking red light.
Try to open the cover then disconnect the inverter board after that try to power it on again..
If the light stays in blue (LIT) and of course you don't have picture or backlight you have faulty inverter board that need to be replace.
Nov 08, 2012 | Sharp AQUOS LC-37D40U BACKLIGHT INVERTER...
I have a lc-d45u sharp lcd that i get sound but no picture.
Ur LCD backlight inverter board is dead.Replaced this board will get picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD backlight inverter board,it a long board shape.
Mar 02, 2010 | Sharp Aquos LC-19D45U 19 in. LCD TV
No picture no sound opc light and power light
This is very common in sharp tvs.U turn it on.U get power on light stable right?U hear a click,one or twice,sometime tv is good right?Sometime POWER light and OPC light flashes?Push the power button on/off couples times will work, picture will come on.If keep trying off/on couples time after POWER and OPC flashes,don't ever stop and never get backlight and picture.Ur Video backlight board is dead must replaced.
Dec 28, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Televison & Video Logo
70 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
