When we turn on our HT-D5610 (could be be HT- S610) we get a message saying "CD/DVC protection" and shuts off. Why.
Posted by Joanne on
Tom Chichester
    Top Expert:
  • Audio Player... Master
  • 57,309 Answers
Probably failure of component(s) on the circuit board
Posted on Aug 05, 2020
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: When I turn on my Samsung HT-TQ85 it says protection and then goo
it may have something to do with parental control
Posted on Dec 27, 2008
Anonymous
  • 121 Answers
SOURCE: i have a samsung ht-tx75 and it keeps shutting
Protection is very likely caused by an over heat condition, even with the fan working if the receiver is in a very enclosed place that warms up and is not ventilated it will cause the problem. The solution is to provide more ventilation so that the receiver can cool itself properly.
Posted on Feb 26, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Protection Problem on Samsung Digital Home Theater
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
svn_blogger
  • 17 Answers
SOURCE: protection and shut down.ht-tx35
I have HT-X40 home theater, but my problem seems similar to yours. It's related to overheating. First check the fan and air flow from it. If it's OK, the problem can be inside the unit. In my case one of the output filter capacitors got broken - it had a crack on its body. Replacement of the capacitor fixed the shutdown on protection.
Another question is what damaged the cap. Preliminary I consider placement of the capacitors as a possible problem - they are too close to the output inductors which can get relatively hot even at normal working condition. For details you can check: http://craftsman-hambs.blogspot.com/2009/09/samsung-home-theater-ht-x40-shut-down.html
Posted on Sep 06, 2009
brian shevack
  • 902 Answers
SOURCE: my ht-z31 dvd surround sound
the protect means a circuit overload check that you dont have any wires for your speakers touching or backwardly installed if those are all fine you may have blown a fuse inside the receiver.
Posted on May 07, 2011
Samsung ht-x30 sutting down protection error
My samsung shuts down with "PROTECTION".Help me to solve the problem.David ilomo.
Dec 05, 2009 | Samsung Audio Players & Recorders
Need help with HT-z410
When your home theater's display reads PROTECTION, it means the home theater is over heating and the unit will shut down to prevent any damage. This can happen if the unit is stacked along with other electronic devices or the unit is in an enclosed area that prevents the unit from cooling properly. To decrease the chance of overheating, relocate your home theater to a more open area.
If the home theater display reads PROTECTION every time you turn it on, no matter where or how the unit is placed, it needs service. To set up service call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
Jun 29, 2009 | Samsung HT-Z310T Theater System
Dvd home theather system
The audio amplifier IC are fried and need to be replaced
Mar 31, 2009 | Samsung HT-X40 System
"Protect" error - HTZ110
Home Theater System Is Displaying "Protection" spacer.gif As soon as the unit is turned on, the word "PROTECTION" will flash on the front panel of the unit and SHUT OFF. This error message usually indicates that the fan in the back of the unit is not on.
The PROTECTION feature automatically shuts down the unit to avoid further damage. The unit will need service if this error message is displayed.
Please use our ASC Locator to find your nearest Authorized Service Center
from samsung's web
http://www.samsung.com/au/support/faqs/supportFaqList.do?group=&type=hometheatre&subtype=hometheatresystems&model_nm=HT-Z110&dType=D&mType=UM&vType=R&prd_ia_cd=03030100&acc_ia_fl=&disp_nm=HT-Z110&menu=faqs
Jan 18, 2009 | Audio Players & Recorders
Samsung dvd home theater HT d5610
This sounds like a short circut (check speaker and other conections to make sure none are touching each other or a metal contact!
That should fix ya!
Dec 18, 2008 | Samsung DVD-R155
Problem "protect"
Hey guys, just had the same problem and found out it was because I had disconnected the central speaker. This it was creating a back impedance or something and reonnecting did the trick! i.e. check your speaker connections and check that they work... duff speakers could cause the problem too!
Sep 20, 2008 | Samsung HT-TQ85 Five DVD 5.1 Channel Home...
Protection
doe sthis do it on all dvd or just 1 is fan out on it in well vented place
Jan 27, 2008 | Samsung HT-DS610 System
66 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
