Question about Samsung Cell Phones
How do you get past no URL I'd screen on my Samsung Galaxy GtS5660M Gio
Posted by Killey Macdeadguy on
5 Related Answers
lawal risqat
  • 352 Answers
SOURCE: My contact numbers on my
The reason the contact is not appearing is because you are using the phone memory contact.
To switch to SIM memory contact, go to contact press select and scroll to setting press select again and scroll to memory in use press select and scroll to SIM card.
Press select and it will bring out your contact.
Regards
Posted on Jun 29, 2011
ertugrul_fcb
SOURCE: my phone SAMSUNG GALAXY GIO
whenever i try to download some programs on android market the phone says 'error code -18' i dont know what to do please help. greetings from ankara
Posted on Jul 30, 2011
francis joan
  • 1696 Answers
SOURCE: I bought a prepaid samsung
If the phone locked to a particular network then you need to unlock the network lock. You can get the unlock code through online. Give your IMEI number & get the unlock code for ur mobile .............You also get through online..........I will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
Posted on Aug 31, 2011
elverasaayma
SOURCE: hi, ive somehow locked the
I did the same. When you are in camera mode the lock/unlock button for the screen also does the same with the camera. I found this out by also having the camera locked and just started pushing buttons
Posted on Sep 08, 2011
Jennifer
SOURCE: how do i set my samsung galaxy gio to beep when i miss a text
Bring up your settings menu, and go to sound settings... You'l see the notification ringtone and you can choose from that menu whatever sound you'd like for your notifications
Posted on Jan 11, 2012
My galaxy gio fell now not working
http://www.samsung.com/ca/support/usefulsoftware/KIES/
( make sure your battery is fully charged )
(1)Do a system Backup with Kies
(2) Go to settings privacy
(3) select the checkbox backup my data & automatic restore
(4) Factory data reset BUT leave format sd card unchecked
(5) Reset Phone
(6) Erase everything
(8) wait for it to restore back to factory settings on your phone
(10) if that didn't work let me know
( GOOD LUCK )
Sep 29, 2014 | Samsung Galaxy Gio s5660
Preciso codigo de desbloqueio para samsung galaxy gio bloqueado a rede vodafone com o imei 359655047481013
Hi whether you want to unlock your samsung galaxy gio s5660 mobile from vodafone network lock ..Then have a look at sites like Theunlockarena.com here they render unlock code for all mobile models at reliable cost ....
Oct 03, 2013 | Samsung Galaxy Gio Gt-s5660 Unlocked
Hi samsung gio won't start stuck in first samsung screen and can't log to recovery mode it gives ramdump and stuck
ram dump if your press vol up+power+home button, but if you wanna go to download mode you must press vol down+home+power button.
it stuck on first screen called boot loop, solution is reinstall or flash new rom on your phone,
follow this http://www.droidvan.com/2012/06/link2sd-on-stock-rom-s5660dxkt8-236.html if you wanna back to stock rom
or this http://www.droidvan.com/2013/03/cm-9-final-for-galaxy-gio.html if you wanna taste off ICS on your phone
Mar 12, 2013 | Cell Phones
Unlock samsung gio s5660
Hi, You can get the unlock code for a Samsung Galaxy Gio S5660 from www.unlock-zone.com/samsung-s5660-galaxy-gio/rs16wp9/ at affordable cost with easy step by step unlocking instructions. all the best mate.
Dec 13, 2012 | Cell Phones
Need unlock code for samsung galaxy gio
If you mean network unlock, you can use the following service for your phone model: http://www.fastgsm.com/en/samsung/samsung/galaxy-gio/unlock-code/unlocking
Nov 07, 2012 | Cell Phones
Are there any free sites for unlocking mobile phones i bought phone n net and dont know who the previous service provider was
Hi here some ways to know which network locked your mobile. they are
1.You can ask the previous owner of your mobile about which network he/she used ..
2. Samsung galaxy gio is a Canadian CDMA mobile .So you try all Canadian CDMA network .If your mobile accept any network sim then it mean its locked to that network.
3.Sometimes locked mobile comes with logo displayed in the top of screen about which network it is locked .ie if it is locked to AT&T then AT&T logo is displayed in top of the screen.
Using the above ways you can identify the network to which your mobile is locked.Then free unlock code are untrustable many times .I guide you to have a look at Theunlockarena.com here they help you unlock your Samsung Gio s5660 mobile from network lock using code.
Oct 13, 2012 | Samsung Cell Phones
Preciso de codigo de desbloqueio para Samsung Galaxy Gio GT S5660 - imei - 357331043524907
Hi, To which network has your Samsung Galaxy Gio GT-S5660 been locked to? You can unlock your Samsung galaxy Gio safer and easier using unlock code. You can get the unlock code from www.wickedunlock.com/samsung-gt-s5660-galaxy-gio/rs11wp9/ at affordable cost.
UNLOCKING STEPS FOR SAMSUNG GALAXY GIO GT-S5660
1 - Switch ON your Samsung GT-S5660 Galaxy GIO with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
Oct 03, 2012 | Samsung Galaxy Gio Gt-s5660 Unlocked
Samsung Galaxy Gio s5660 arabik
go to the goole play store and down load the app for that language keyboard..its a free app i just looked
Jun 12, 2012 | Samsung Galaxy Gio s5660
Free unlock codes for samsung galaxy Gio
Free codes does not work some times..So better you will get the code from http://www.mobileunlocksolutions.com/ .It helps to unlock your samsung mobile easily.
Apr 09, 2012 | Samsung Galaxy Gio s5660
Invalid sender samsung galaxy gio
hi
i need help to debrand korean samsung adb modle (Glaxy Gio) Shw M290K.
i am facing msg send problem in this phone. when i send msg its appear (your msg has invalid sender) even msg Center is correct.
unit firmware is 2.3.4.
now please guide me how to fix this problem.
Replay me urgent.
Mar 24, 2012 | Cell Phones
Cell Phones Logo
66 people viewed this question
Top Samsung Cell Phones Experts
Felizardo Erilla
Felizardo Erilla
Bill Long
John Tripp
John Tripp
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
