Question about Hardware & Accessories
Where do I get instruction sheet for noma christmas tree remote model 052-8849-0
Posted by Ellen Murphy on
Tom Chichester
    Top Expert:
  • Hardware & A... Master
  • 56,006 Answers
Possibly from NOMA
Posted on Aug 07, 2020
5 Related Answers
Anonymous
  • 803 Answers
SOURCE: HELP WITH A CHRISTMAS TREE
As for all of us as Experts at Fixya. We would greatly appreciate if you would place your question in the right category so that an Expert with knowledge of this field can provide you with help. Sorry that I could not be of more assistants. I will inform other experts in this field of your issues so that they can redirect to help you. Thank you for using Fixya.
Posted on Dec 09, 2009
gggg
  • 904 Answers
SOURCE: artificial Christmas tree comes in 3 parts A B C
You can probably find instructions online, depending on the maker. What kind/brand of tree is it? Do each of the power cords plug into the next one down, or is there a large multi-tap outlet somewhere (either halfway up the tree or at the base)?
Posted on Dec 13, 2010
srtour2011
SOURCE: I have the gemmy musical
I have a remote, and three trees, but no power transfomer. feel free to write me at [email protected]
Posted on Dec 19, 2010
Anonymous
SOURCE: how do i reset the remote for the gemmy led
push the reset button on the box under the large tree then whine it is flashing push the reset button on the remote. Its on the back in the middle. Use a paper clip end.
Posted on Dec 25, 2010
emissionwiz
Marvin
  • 85239 Answers
SOURCE: i need a new remote for my christmas trees
I am sorry we have no parts resources.
Posted on Dec 18, 2012
Everstar 4 piece Christmas tree, how do I hook up lights?
Setting Up your Pre-Lit Christmas Tree - YouTube
? 4:56
https://www.youtube.com/watch?v=qe1fbGZV-Ys
Jul 3, 2008 - Uploaded by Christmas Central
Here are instructions on how to put up your pre-lit Christmas Tree, courtesy of http://www.christmascentral ...
Video: How To Assemble a Pre Lit Artificial Tree by Sterling ...
www.christmascentral.com/t-Video-How-To-Assemble-a-Pre-Lit-Artifici...
Learn how to assemble your Artificial Christmas Tree in less than 10 minutes! Sterling Inc has teamed up with Christmas Central to make this instructional video; ... Do you want to learn how to decorate like the pros? ... These lights can be used for all kinds of visual motion effects, from a waterfall to a flashing starfield!Missing: everstar
We purchased an Everstar pre-lit Christmas Tree - Fixya
Dec 12, 2015 | Home
Artificial Christmas tree comes in 3 parts A B C
Dec 19, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
MY 3 PIECE GEMMY CHRISTMAS TREES STOPPED WORKING THE SPEAKER FOR MUSIC JUST KINDA HUMMS AND THE LIGHTS WILL NOT WORK
Here's what you do... This is for the trio christmas tree light show.
What you need.... small precision pointing tool.
On the largest tree base electrical box there is a push button. Press and release that button. A red led will flash indicating the box is in sync mode. turn the remote on and on the back of your remort, there is a small hole with the words reset over the top of it. Using the small precision pointing tool, press the recessed button and release. The remote will sync to the base unit. Walla!! Merry Christmas to all!!!
Nov 29, 2009 | Gemmy Toys
We purchased an Everstar pre-lit Christmas Tree and we can not locate the manual or instructions that came with the tree any help since half the tree doesn't light up and all the plugs are plugged in....
I have a 3 piece Everstar 7/12 slim pine and here are the plug portion of the assemblly instructions . "1) connect the plug(A1) of string with the end cord (B1) of string. 2) Insert the plug (B2 & C1) of string into the wall outlet. 3) After the plugs are plugged into the wall outlet your entire tree should be lit. If some bulbs do not light, search for any loose plugs, broken, loose or missing bulbs that may have caused the problem."
My illustration shows the A1 in the top section of the tree while B1 is in the middle section. Both the middle section and bottom section get plugged into the wall or extension cord. Hope this helps
Nov 28, 2009 | Solar Christmas Tree 6 Outlet Foot Switch...
We bought the Gemmy Christmas tree trio last year. Just set it up today and the light show effects will not reset. Can't find the instruction manual
Press reset on the top of the main unit under the middle tree. The light will blink. While it's blinking, use a pin to press in the reset button on the back of the remote. The blinking light should go out, and you should be good to go. FWIW - I just looked for almost an hour before I found this answer today on-line. It worked for us.
Nov 27, 2009 | Gemmy Toys
Hardware & Accessories Logo
116 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
