Question about Technics Audio Players & Recorders
I have a Technics SA-DX850 receiver with F70 error code.
If i select TV digital input, then i don't have error code. When i switch to TV analog after few second i got the error code again.
Posted by Bla Barth on
Ngoro
    Top Expert:
  • Technics Master
  • 2,711 Answers
5 Related Answers
Michael Borelli
  • 979 Answers
SOURCE: F70
The system has detected a fault in the output section. How much are you asking of the system? Greater than 50%? That will push most systems to their limit in a short period of time...accordianman
Posted on Jan 14, 2008
Michael Borelli
  • 979 Answers
SOURCE: Could anybody tell me what F70 means ?
You must have air flow through this unit!...accordianman
Anonymous
SOURCE: Panasonic SA-HE100 5.1 system error code F70
I was able to fix this problem by replacing a fuse. Remove the cover (7 screws). Directly behind the fan are 2 boards with 5 fuses on them. The boards are 1 over the other. The fuse I replaced was labeled F5 and on the top board with the fuse facing down on the underside of the board.
Posted on Jun 23, 2008
Anonymous
SOURCE: technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Posted on Sep 24, 2008
Anonymous
  • 86 Answers
SOURCE: TECHNICS SA-DX850 F70
It could be an overload from two speaker wires crossing, check the owners manual for error codes.
Posted on Dec 22, 2008
What causes f70 code
This may be blown fuze. This is an informative forum. Read answer one-third down page. Hope this helps Technics stereo receiver F70 error code CK5 Forums
Mar 11, 2015 | Technics SA-DX750 Receiver
Digital input glitch, switches randomly from analog to digital.
what connections do you use for the device you are listening to, and what device are you listening to when this happens. you should use either an analog, or a digital connection to a device, but not both
Mar 08, 2013 | Technics SA-DX930 Receiver
Digital surround mode doesn't work,just analog dvd 6ch.input
Failure of the sound processor. All you can do is to remove the cover, clean the insides, check the cables to make sure they are still firmly plugged in and then measure the 5 volts power line from the source. If all appears OK the the processor has died - a replacement board is mandatory. It will be cheaper to buy a new receiver .
Sep 29, 2011 | Technics SA-DX850 Receiver
SA-DX750 error F70
I have a technics sa dx 750 receiver that cut...
Dec 21, 2010 | Technics SA-DX750 Receiver
System overload (technics sa dx-850)
audio amplifier IC damaged need to be replaced
Sep 25, 2010 | Technics SA-DX850 Receiver
Problem with Technics SA-DX850
SA-DX750 (sister Model to SA-DX850). Showing error code F70, after a few minutes running. Checking the power rails revealed +5VA and +5VD, on the Digital Circuit Board 'A', dropping to about 2V, when fault occured. F5, T1A, on the Sub-Transformer Circuit 'M', was subject to occasional blowing. The problem was traced to an intermittent break, in the printed circuit board conductor, in the vicinity of Q1702 (+5VD regulator) collector, on the Digital Circuit Board 'A'.. Repairing this cured the problem. Note that removing F5 (above), or disconnecting CN702, CN1000A or CN904B, on the Digital Circuit board 'A', also causes this error code to be displayed. Failure of the audio output ICs, IC651 & IC801, is apparently the usual reason for this error code being dsiplayed, but it is worth checking the power rails viz. +/- 25V (Fuses F3 & F4, T6.3A, on Sub-Transformer Circuit 'M') +/- 55V, +/- 14V etc.
Aug 11, 2009 | Technics SA-DX850 Receiver
Dec 22, 2008 | Pioneer VSX-818V-K Receiver
F70
Jan 14, 2008 | Technics SA-DX850 Receiver
Dec 04, 2007 | Technics SA-DX850 Receiver
F70 Error on SH-AC300
unit has a blown internal fuse. replace it with exact type of fuse and see what happens. if it blows again, it will need to be returned to a service agent
Sep 25, 2007 | Technics SA-DX950 Receiver
99 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
