SOURCE: purchased a used earth stove mp240 pellet stove
The auger motor is fed through a high temp. limit thermostat. It has a
manual reset on the back of it that you have to press on firmly to
reset it. Open the side panel on the stove and find the wiring. You
will see the thermostat on the back side of the combustion chamber.
Look very closely and reset it.
good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Jul 01, 2009
SOURCE: pellet stove
PRESS H THEN TROUBLE THEN START THEN HIGH 6 THEN LOW 1
THEN PRESS BLOWER & HIGH FOR 3 BEEPS
Posted on Feb 22, 2010
SOURCE: Pelpro pellet stove will not start. Press the start
Is the auger light coming on to and dropping pellets into the burn pot? If the auger light is not coming on, you probably have an issue with the board controlling it. If the auger light is coming on, and pellets are dropping into the burn pot and it is still not lighting, then you have only a few other possible problems.
1. The air damper is not allowing enough air in, so pull the damper rod out 1/8" increments until it lights.
2. Your ignitor is faulty and not producing enough heat to light the stove. You can either contact a local dealer and get a replacement ignitor, or you can manually light the stove with a special firestarting gel made for pellete stoves. When you press the start button look into the burn pot. If the ignitor isn't bright orange, you aren't getting enough heat from it.
Hope this helps...good luck.
Posted on Nov 15, 2010
SOURCE: I have a Quadra fire 1200 pellet stove insert. The
It may be working properly. If it seems that it's a little cool in the room and the blower is cycling like you say then the stove may be getting chilled. If this is the case then the low-temp switch is cutting the blower off.
If the room is quite hot there may be a problem with the blower. Check to see if it has a bunch of dust in it making it run hot and tripping the internal thermostat.
Please respond with the 'comment' button, down below the ads. I'm considering a pellet stove and I'd like to hear anything you have to say about yours.
lp
Posted on Jan 11, 2011
Jan 28, 2018 | Cars & Trucks
Jan 17, 2016 | Cars & Trucks
Oct 21, 2015 | Pool & Spa
Oct 20, 2011 | Napoleon Auburn Pellet Stove Heater
Jan 17, 2011 | Napoleon Auburn Pellet Stove Heater
Jan 11, 2011 | Napoleon Auburn Pellet Stove Heater
Oct 21, 2008 | Heating & Cooling
Sep 30, 2007 | Stoves Broan 40000 Series Hood - 36" Hood...
Dec 23, 2020 | Intex Pool & Spa
90 people viewed this question
