Question about Samsung Televison & Video
First understand that you need a little patience with this remote, it's a little slow, it may take a few seconds in between pushing buttons for it to react to your TV.
1)
-Turn on TV manually first.
we're going to try and get the remote paired to your particular tv
2)
-Facing RCA universal remote towards TV, press and hold both the POWER and TV buttons on the remote at the same time.. until the RCA universal remote POWER button lights up and is constantly on.
-Then press the PLAY button on RCA universal remote
(POWER button on remote should be blinking after pressing PLAY -- what the remote is doing is trying to program your TV with a list of codes. if your TV does not automatically shut off after a minute, press the PLAY button again. your TV should shut off. wait a few seconds before trying to press PLAY button again if you need to try again.)
3)
Assuming remote turned off TV. Now let's try to get the remote to turn on your TV
On the remote at top right is a REVERSE button, press that. You should see the POWER button on the remote blink once in response to you doing that.
Watch for the power on light on your TV.. your TV may take a few seconds to power on..
Wait a couple seconds. if your TV has not turned back on, press the REVERSE button again. the POWER button should blink once again in response
If your TV did not turn on. You may have to repeat pushing the REVERSE button waiting a couple seconds for the remote to try turning on your TV. For some people this can take several times, if not a dozen times. Just be sure to be patient and wait a couple seconds in between pressing the REVERSE button again. (what the RCA universal remote is doing is going through a list of codes trying to find the right model to pair to)
4)
Assuming the remote finally turned on your TV.. We are almost done. We programmed the remote to turn off the TV and turn on the TV. now we want to press the STOP button on the RCA universal remote to lock in those codes into the remote. After pressing the STOP button the light on the remote POWER button should turn off.
5)
We are done. You should be able to change the channels and raise and lower the volume of your TV.
Posted on Dec 10, 2020
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
SOURCE: program the RCA#rcr312 universal remote control
I have the book, but can't get mine to work, email me at [email protected] and I'll scan it and email it to you. I just can't figure mine out
Posted on Mar 14, 2009
SOURCE: tv code to use a rca universal remote
I have a remote for my tv by universal-remocon and can not find the manual with the code for a magnavox tv and how to program it. I have no code, it doesn't work.
Posted on May 29, 2009
Code For Model RCR311S Code 1003 for Panasonic TV Code 1054 for Panasonic TV Code 1062 for Panasonic TV Code 1109 for Panasonic TV Code 1170 for Panasonic TV Code 1248 for Panasonic TV GOOD LUCK THESE ARE THE CODES LISTED FOR YOUR REMOTE/
Posted on Jun 03, 2009
Feb 03, 2016 | Samsung Televison & Video
Jan 19, 2016 | RCA Televison & Video
Dec 02, 2015 | RCA Televison & Video
Nov 24, 2013 | Samsung Televison & Video
Jul 23, 2010 | RCA F32674SB 32" TV
May 05, 2009 | RCA Universal Remote 3 Device Remote...
Jul 30, 2008 | RCA RCR660 Remote Control
