Question about Optics
Where can I purchase a rifle shot tube for daisy red Ryder #111 model 40
Posted by Ronald youngs on
5 Related Answers
Anonymous
  • 31 Answers
SOURCE: does not hold air to shot
try oiling
Posted on May 15, 2009
cyknight
  • 14 Answers
SOURCE: i have a daisy model #111 that does not fire
It sounds like the sear pin spring has broken. If it's as old as mine is (very near 40 years old), it would be no wonder! You'll have to carefully open the mechanism and check it. Springs are made that will perfectly replace a broken one; other parts for this particular model are extremely scarce. Good luck with the repairs.
Posted on Jul 27, 2009
Anonymous
  • 20 Answers
SOURCE: Daisy Red Ryder BB gun won't shoot
1) **** the gun and look through the hole in the top, half way down the barrel.
2) You should see a BB loaded into this area.
- if no bb is present and you can see a circular magnet, then it is not loading.
3) if the bb is present and does not exit the barrel when you fire the gun, then the bb is deformed and will require the rifle to be dissasembled and rodded through the back side, forcing the bad bb out of the way.
4) If no bb or magnet is present through the hole, call daisy for a replacement. This indicates the shot tube has moved and will no longer load.
Posted on Aug 17, 2009
Freddyyesme
  • 548 Answers
SOURCE: Looking for manual for an old Daisy Air Rifle.
what you thought was the serial number is actual the state and zipcode for daisy air rifles in rogers arizona, 72756 but try this page here and see if it can help you
http://www.daisy.com/_manuals/spring_air_english.pdf
Posted on Sep 14, 2009
mash_jumbie
STEPHEN DOWNING
  • 138 Answers
SOURCE: How can I get a replacement part for my BB gun NO.
try this link it has all the info u need
http://www.daisyrepair.com/parts.htm
information
Bucky's Daisy Parts & Sales
Ron & Jenn Scalzo
1338 Hibiscus Drive
Cape Coral, FL 33909-5113
239-458-8787 ----[email protected]
Posted on Mar 05, 2010
I just bought a model 99 daisy and it shoots out 2 b b's at one time. Any fix for it?
you might consider ordering a new style shot tube from the Daisy Museum, I think they sell them for $12.00 plus a small amount for shipping; they were made for the Model No 25 (re issued) can be used in the Models 99. This replacement is far superior to the old tube. For the old type of shot tube it is normal for it to shoot two bbs when first loaded as it chambers a bb when shot tube is installed then you **** the rifle and it chambers another one.
Jun 11, 2017 | Daisy Toys
Daisy repair
My Red Ryder B B gun is jammed-I have shot and shot it still no bb willcome out
Jan 03, 2014 | Daisy Model Red Rider Rifle 1938 BB Guns...
After pumping up the rifle it had very little pressure
The piston seal has failed, or the pressure valve. Daisy manufactures in China now. If its a Red Ryder or other cheapie, then its a spring loaded gun and additional pumps do nothinga
Feb 18, 2011 | Daisy Toys
Where do i oil the gun
On all the Daisy BB rifles I've seen (and on the Model 111 I've had for almost 40 years), the oiling hole should be on the top of the barrel, with the words "Oil Here" stamped around the hole. Hope this helps.
Jul 14, 2009 | Daisy Toys
NEED THE COCKING HANDLE FOR RED RYDER AIR
Recommend an eBay or Google search or contact Daisy directly here:
https://www.daisy.com/contactus
Apr 09, 2009 | Daisy Toys
Optics Logo
87 people viewed this question
Top Optics Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Optic Expert? Answer questions, earn points and help others
