Question about Proscan Televison & Video
Proscan 26"lcd 26LB30Q not getting power, won't turn on
Posted by Denise Viar on
  • Denise Viar
    Denise Viar Dec 18, 2019
    Well it was working, I unplugged it to move it, just four feet, plugged it back in and it hasn't turned on since.
5 Related Answers
VOTIT
LORETO LACARON
  • 2071 Answers
SOURCE: the screen turns on hen off
Just try to reset;
Resetting the TV
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can saved time.
1. Unplug the TV power cord from the power outlet for 3 - 4 hours.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Posted on Sep 17, 2008
Anonymous
SOURCE: how to remove base support from PROSCAN LCD TV( model 26LB30Q)
Remove the srews under AUDIO-L/R and HDMI-1.
Posted on Mar 30, 2009
rainsocket
  • 32 Answers
SOURCE: Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Posted on Apr 02, 2009
Anonymous
  • 7 Answers
SOURCE: 26" Samsung flatscreen LCD doesn't power up
Just to be a little more detailed, since I just fixed this problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
Anonymous
SOURCE: I need the remote control code for Proscan tv with dvd player
Don't know if the 26" is the same as the 32, but 10019 works for the 32".
Posted on Jan 18, 2010
I need to download the user manual for the product described below.
looks llike you may have to pay for it. see link below
Jun 05, 2015 | Proscan Televison & Video
I have my computer hooked up to my proscan 26LB30Q. The power will come on, but it only stays on for about 30 seconds. What do should I do to make it stay powered on?
How are you interfacing your computer to the tv? HDMI? RGB video cable?? Some tv's especially Vizio's will automatically turn off if it doesn't sense a video signal on the RGB input after about 30 seconds. Make sure your computer is putting out a video signal.
Sep 24, 2011 | Proscan 26LB30QD 26 in. LCD HDTV
I bought a Proscan 26LB30Q TV. After connecting to the indoor digital antenna, no signal showed up on the screen. What could be wrong? Thanks.
MAKE SURE WHERE YOU HOOKED UP THE ANTENNA SAYS DIGITAL,,IF ITS NOT IT WANT WORK ON TOUR TV,, POEPLE THINK JUST CAUSE ITS A NEW FLAT SCREEN THAT IT DIGITAL,,, BUT A LOT OF THEM STILL ARE JUST ANALOG ANTENNA READY,,,,,THE ANTENNA JACK SHUOLD SAY EITHER ANALOG OR DIGITAL,,
May 15, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
My proscan is buzzing and pix is flickering when the power is on.
I found this solution on another review, hope it works
Model Number: Proscan 26" LCD HDTV w/ Built-in DVD Player26LB30QD "pro: good price, TV picture is clear and DVD player is compatible well.
con: sound noise
There was hum when I first turned the TV on, then I followed these instructions (found it from other review) to fix the hum issue:
1. Turn tv on
2. Input mode should be tv
3. Turn volume to zero
4. With remote enter 9 8 7 6
5. A menu will appear on left side
6. Arrow down to backlight and with right arrow key move number from 81 to 83, press menu button twice,
7. Turn up volume and listen if hum is gone."
It works,no hum."
Feb 26, 2009 | Proscan 42LA30H 42 in. LCD Television
What remote do I buy for the Proscan LCD 26lb30q?
Try Ebay they have them the item number is 350167917823 just type that in the top where you would put in what you want to find.
Feb 25, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Looking for a wall mount that fits the ProScan 26LB30QD
I purchased a Level Mount DC30SJ from Walmart online, then called Level Mount and they sent an adapter plate for no charge. It works great and was easy to install.
Feb 16, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
The screen turns on hen off
Just try to reset;
Resetting the TV
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Sep 14, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Televison & Video Logo
60 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
