Question about JVC Televison & Video
My JVC remote RM-SXV067A controls a TV and DVD. There are no buttons that light up on this remote. There is no Code Search button either. I just want to control my JVC tv with this remote. And I would like to be able to get into the tv menu also. Could someone tell me the steps to do this? And please don't reply 'refer to your manual'. If I had a manual I would not be asking for help. Thank you in advance.
Posted by Tina Jones on
Tom Chichester
    Top Expert:
  • JVC Master
  • 55,995 Answers
Press the TV button, then the power button. If your TV starts, you are on your way. There should be a button that brings up the menu.
Posted on Dec 17, 2019
  • Tina Jones Dec 17, 2019
    There is no power button.
5 Related Answers
Anonymous
  • 50 Answers
SOURCE: emerson tv codes for GE RM-24930 4-Device Universal ...
check this site for your codes. (Jasco is GE)
http://www.jascoproducts.com/support/universal-Remote-codes.asp
Posted on Nov 18, 2007
Anonymous
  • 13 Answers
SOURCE: jvc remote control
"i already paid for the tv so why pay for something that should be readely available to me in the first place I should have access to all the features on the tv ".. WRONG!!!!!!!!!You should have a warranty for this TV but it's old , anyway. First,receive a reference image (let's say CNN).Second:press "Sleep Timer" key and set the value to "0". Then press "Display" and "Video Status" keys at the same time. Third: use "Vol +/-" and " Channel +/-" to select "2.DEF(D)".Go to "D03: V.SIZE" and modify step by step the value for best fitting. There is also switch " SW401" on the main board for centering the image . Finally, press "EXIT" key till you exit the "Service Menu". Don't try to modify anything else!!!!!!!!!!!!!!!!!
Posted on Nov 20, 2007
Anonymous
SOURCE: Lost my manual for RCR4358 remote control
Press and hold TV and Power buttons until light is red. Press PLAY once, if TV does not come on press again untill TV comes on. Then press REVERSE until TV goes off. Last, hold down STOP until light goes off. I had to do this a couple of times, but it worked!
Thank so much,
Jo Ann
Posted on Jul 05, 2008
the q guy
Tony Walker
  • 393 Answers
SOURCE: No Code Search button
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
if this helps please give a fixya rating as thats how we get paid.
Posted on May 21, 2009
Anonymous
SOURCE: LG DVD Remote for controlling TV
I found the DVD LG DVS-8575N manual in spanish on http://safemanuals.com/user-guide-instructions-owner-manual/LG/DVS-8575N-_S
Procedure:
Press at the same time POWER TV and a code number.
TV - Code number
LG / Goldstar: 1 or 2
Zenith: 1, 3 or 4
Samsung: 6 or 7
Sony: 8 or 9
Hitachi: 4
Posted on Jul 11, 2009
I need remote control code for Dawin TV
If you do not know the code, you can use the code search function to program the remote control.
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Apr 04, 2016 | Televison & Video
How to program JVC Remote RM-SXV067A Remote to TV
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 20, 2012 | JVC RM-A5 Remote Control
I have a samsung tv i am trying to trying to program for this jvc remote. Could you give me some instructions?
Hi wnowens, to program your tv to that remote follow these 3 easy steps.
Samsung code = 12
1 Holding down TV/VIDEO, enter the code "1 2" by using the numeric buttons (0 - 9).Do not release TV/VIDEO. Keep holding it until the next step is completed.
2 Press STOP button while holding down TV/VIDEO.
3 Now try to operate your TV by pressing DVD POWER - TV POWER while holding SHIFT.
If your TV turns on or off, you have successfully set the control signal.
If you want a PDF copy of the user manual click HERE to download it.
Hope this helps enjoy : )
Feb 11, 2011 | JVC Rm-sxv521j Remote Control
To program my TV JVC
Manual code entry
1.Turn on your television or other electronic component that you want to program the remote control for.
2.Hold down the "Code Search" or "Setup" button until the LED indicator light turns on.
3.Hit the button for the component that you are programming (TV,DVD VCR, etc.). The LED light should flicker and stay on.
4.Enter the 3-digit or 4-digit code that corresponds to the TV or device that you're operating.The LED light should go off if the code is valid, but will flash if it is not. Try other codes you have.
5.Try turning the television or other programmed component off to ensure that the remote works properly, once the light has gone off.
Auto configuration
3.Hit the button for the component that you are programming (TV, DVD, VCR, etc.). The LED light should flicker and stay on.
4. Press and release the "Power" until the television or other component turns off while waiting at least 2 seconds between each press.
5.Press "Enter" or "Save" once the remote has effectively turned the power off. The LED light will shut off and the remote will now operate the device.
Codes for JVC TV are
3 digit codes:
013, 012, 026, 054, 055, 060, 065, 067, 069, 089, 141, 197, 247, 901
4 digit codes:
0060 0026 0197 0069 0160 0247 0923 0012 0065 0067 0141
Thanx
Aug 04, 2010 | GE JASRM24912 Remote Control
I have a jvc television and bought a universal remote. i dont know the code for the remote. do you know the code?
These are the steps on how to program your Universal Remote Control to your JVC TV even without the list of code.
1. Manually turn ON your TV.
2. Press and "HOLD" CODE SEARCH
3. Press and release the TV button you want to set up
4. Release CODE SEARCH.
5. Press OFF/ON repeatedly until the TV turns off (you may have to press up to 100 times at a rate of once per second).
6. Once the TV turns off, press and release ENTER.
7. With the TV on, press any other button. If the TV responds, no further programming is required. If the TV does not respond, repeat steps 1-6.
Jun 14, 2010 | JVC RM-C18G-1H Remote Control
Code no.?
This information is to search for any code using the SONY RM-VL990T Universal remote:
Using the code search function: Press [S]. All Component Select buttons will flash. Press the button you want to configure. Press [CH+] or [CH-] and [POWER] in turn until the component turns on or off, then press [ENT] to save.
May 09, 2009 | Sony RM-VL900 Remote Control
Need instructions on programming
JVC offers the manual through their website:
See this link:
http://books.jvcservice.com/booklist.asp?Model=XV-N50BKJ
That's for the DVD player XV-N50BK. Check your model number before going with that manual. If that's not your model number, look on the left side of the page where the link is at and you will see a link for getting user manuals. Just enter in your model number and it will give you a PDF that you can download, save, print... whatever.
Jul 16, 2008 | JVC RM-SXV038J Remote Control
Remote control RM-810
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching
1. Turn on the TV
2. Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once.
3. Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on.
4. Release both buttons. The indicator light will flash constantly indicating the automatic search mode.
5. After the indicator light illuminates, release the two keys simultaneously.
6. If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller
7. Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
Jun 23, 2008 | Philips Magnavox Learning Universal Remote
Tv code
www.usersmanualguide.com/sony/remote_controls
Nov 04, 2007 | Sony RM-V310 Remote Control
Televison & Video Logo
35 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
