Question about Furniture
Why does my Rotec electric bed beep when I try to use the remote? Is stuck in the up position.
Posted by Todd Tamboline on
Finding the reset button on the motor
You posted in the vacuum cleaner forum
May 24, 2018 | Vacuums
Have a 2017 jayco freedom motor home with the electric bed. Bed is stuck in the up position & will not come down
20160912_145359-zvse2t43rh2wgzoypk0ynhom-4-2.jpg Here is an example of a Tempurpedic electric bed. Depending on your preference to find a cure or to just woke a band aid to give temporary results. On the first picture you see the screen lever attached to frame rail to raise and lower the head. If you remove the cotter pin and push out the connecting pin, you will be able to detach the motor drive system to lower the head for sleeping. On the other hand, the second picture shows the motor assembly. If you can detach it vs trying repair it in an awkward position, you can open the casing to check the screw drive that extend the shaft that you just detected. While there, check the wiring and plug connection to make sure everything is solid. If you have an assistant and a multimeter, you could also check to verify you have voltage, which should be 120VAC, when the switch is being pushed to raise as well as lower. Maybe check the plug and power before disconnecting anything, just in case.
Feb 23, 2018 | RVs
Bed foot is stuck in the up position
Try resetting the remote control and control box also check batteries
Feb 21, 2016 | Ergomotion US400TL59MNE 400 Series...
Bed not responding to remote
Wow, I have the same problem! I've called & emailed the Vivon Company (never responded) as well as Brookstone (said they can't help). WTF, this was an expensive bed! I should be able to use the great features. Sure hope someone responds to this post from Vivon! Good Luck!
Dec 05, 2013 | O4Jfurniturewarehousecom Vivon Joy 12 Loft...
WIRELESS REMOTE CONTROL - MODEL - r2t3/r2t4. Wonder if you can help please! Have an Electric Adjustable Bed with a remote which has stopped working. Details on the back of the remote are - Model No:R2-T3....
I have a remote for adjustable bed that won't work. I know it is the remote, because I put a new 9V battery in and the red light doesn't come on. Model No:R2-T3. FCC ID: MGB _R2-T (03-680252-03). I see someone posted the same problem and don't see any recommendation to fix or replace it.
Jan 05, 2011 | Televison & Video
I need a craftmatic adjustable bed wireless remote controll
I have a Craftmatic wirless remote control. if you still need one go to http://www.adjustmybed.com or email me as [email protected]
Mark
Jun 20, 2009 | Kitchen Appliances - Others
Furniture Logo
107 people viewed this question
Top Furniture Experts
Tom Chichester
ray gallant
Are you a Furniture Expert? Answer questions, earn points and help others
