Question about Pride Health & Beauty
Problem With Pride Victory 10 Scooter When Powered Off
The blue light at the bottom of the power meter goes to flashing and after a few minutes the first light on the charge meter comes on. Also, the horns will beep and the light will come on but weakly. (Not supposed to do that) If I turn the scooter on, it will run but I am wondering if there is something going on that's a potential problem or if there is something simple I need to adjust or look at.
Posted by James Guill on
jws1013
  • Pride Master
  • 1,708 Answers
The flashing light is flashing a code that indicates an electrical problem. See your manual for the codes on pg 38.
Posted on Dec 14, 2019
5 Related Answers
Dan Hudson
  • 118 Answers
SOURCE: Pride victory mobility scooter
1. Remove the four screws on the outside perimeter of the console base.
2. Lift off console top cover and disconnect the front-to-back cable.
3. Remove the throttle lever from the throttle pot.
Remove the four screws holding the console base to the mounting plate.
Posted on Nov 27, 2008
oregoon
  • 175 Answers
SOURCE: THE SCOOTER MAKES A HIGH PITCH NOISE WHEN THE KEY IS TURNED ON
The buzzer is a piezo-electric device that is the "horn" for the scooter. It also will alert when the scooter is in reverse, if this option is programmed into the scooter. It receives its power from the PC board or console board which is located inside the top of the shroud at the tiller, where the thumb paddles that direct the scooter are located. If liquids have reached the board, or if condensation has affected the board, the circuit that controls the buzzer may have shorted causing it to come on constantly.
Opening the top of the shroud is fairly simple. Remove about 6 screws holding the clamshell cover together, remove the speed adjust knob, and it should come apart. Inside you'll see a PC (printed circuit) board, green in color with lots of small electronic parts embedded on it. The buzzer is also inside, usually about the size of a marshmallow and black in color with tiny holes to let the noise escape. There will be two wires leading from the buzzer to the plug-in at the PC board. Unplug the buzzer and the noise will stop, but you won't have use of the "horn" at all. Replacing the PC board can be done by a certified Pride tech, but it will probably cost you about $150.00 for parts and labor.
Hope this helps.
Posted on Jul 07, 2009
oregoon
  • 175 Answers
SOURCE: I have no manual for my Pride victory mobility scooter
http://www.pridemobility.com/pdf/owners_manuals/US_Scooter/US_Victory_10_om.pdf
Click on this link and a pdf manual for a Victory 10 will appear.
Posted on Aug 28, 2009
Will
  • 25 Answers
SOURCE: I have a pride Victory 4 wheel scooter. Ran great
possibly burnt one of the motor brushes, you can remove the brush, and clean the face of the brush or put new brushes in
Posted on Sep 15, 2009
gewiz
Rob Hill
  • 1414 Answers
SOURCE: I have a pride victory scooter and at low speeds
that could be the speed pot , try moving the throttle lever upwards to see whether it stops shuttering, if not check the motor brushes.
Regards
GeWiz.
Posted on Oct 06, 2009
My pride victory 10 lx scooter will not come on after charging for several hours. When I turn the switch only blue light under power level indicator comes on. No flashes
Hi check the circuit breaker ( reset button ) if this has tripped most of the electrical circuit will shut down :::: push the circuit breaker...cheers
Jun 13, 2018 | Pride Health & Beauty
Controller flashes 9 times what does that mean
Basic Troubleshooting Instructions - Pride Mobility Products
www.pridemobility.com > Resource Center
Pride MobilityINFINFB2468 Jazzy 614/Jazzy 614HD with Dynamic Controller Troubleshooting ... LiftChairs. INFINFB2061 Basic Troubleshooting Instructions: Lift Chairs ...
Pride Mobility Products Corp. - Product Owners Manuals ...
Pride MobilityHelp Me Choose · Where to Buy · Request to Be Contacted · View all Models. Pride Mobility Scooters ... Power Chair Consumer Safety Guide .... Version / Date. Flash. C 01/04. Pride LX Series. C 05/08. Z-11. B 07/04. Manual Wheelchair ... Travel Scooter Throttle Control Lever Operation Product Insert ... Victory 9/Victory 10 ...
Troubleshooting / Repairs Mobility Scooter, Power ...
Dec 03, 2015 | Pride Mobility Pride TSS300 Power Chair -...
His I've a victory xl mobility scooter and constantly red flashing on battery meter and don't charge battery's properly can u help cheers
Hi, at a guess I would say that your batteries possibly no longer hold a charge. If the scooter has been provided for you get the organisation who gave it to you to check it over, they should service it for you.
There is a link below for the website that provides an owners manual, this may help you troubleshoot the problem
If you need anything else please post another query.
Pride Mobility Victory XL 4 Owner Manual
http://www.manualslib.com/manual/718600/Pride-Mobility-Victory-Xl-4.html
Jul 16, 2015 | Health & Beauty
I have no lights while charging only power light, what can I check
Hi, what on the scooter or on the charger, the scooter should not be powered while charging ...
Regards
Rob
www.facebook.com/gewizrepairs
Oct 29, 2014 | Pride Victory 9 4-Wheel
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
My victory 3 loses power. After about 13 minutets of riding, the motor gets hot and trips the circuit. Batterey meter when the throttle is pushed, goes to yellow before it trips the breaker. After a...
either a battery or cable problem long stretch would be breaker and lastly motor if cables get hot try replace them first with larger wire sounds like a resistance problem assumeing your batteries are good and motor brushes good
Jul 01, 2014 | Pride Mobility Victory 3 Wheel Electric...
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
Jan 14, 2014 | Pride New Mobility Victory XL 4 Wheel...
Health & Beauty Logo
106 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
