Question about Kenmore Refrigerators
Would you tell me why you want to repair this water line? I'm not clear about the problem you are having. To prepare the refrigerator for service. You will need locate the shut off valve to the refrigerators water supply line. After the water is turned off. You can slowly and carefully pull the appliance away from the wall. If the water supply line to the refrigerator is copper tubing. You want to move the unit as little as possible. The more it is moved the more there is a chance of developing a leak. Depending on the installer, they may have used copper or nylon tubing. Copper is similar to metal in the respect that if the line is bent repeatedly. The material will weaken and could crack. This will not happen quickly. It's just a good practice to leave it alone and move it only when necessary. Please write back and explain where the unit is leaking and let me know if you are referring to the water supply line going to the refrigerator. If you suspect that the water line inside the door is leaking please tell me where. It is a common mistake that owners think their refrigerator has a damaged hose. In actuality the water control valve assembly is worn out and leaking. Feel free to write back with any questions and I'll do my best to help you figure this out. You don't want to waste your time pulling a door apart when the problem wasn't even there to begin with.
Posted on Dec 14, 2019
SOURCE: Remove Doors on Side by Side Kenmore Elite Refrigerator with water tube
this is the new style connectors push in on the blue end of the connector and pull on the hose it will come out of the quick connect connector
Posted on Apr 25, 2008
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
SOURCE: Replacing water line in freezer side door
Yes as I stated on other posts, go to an appliance shop and get a threaded connector. Mine cost about $7 and i had to do some minor adjustment cutting to the plastic guard at the bottom of fridge/freezer...so the new piece would not put too much pressure on the line. The white coupling connector on the line u will see has a red and blue washer conected on eitrher side of water line. To disconnect line ..just push in on top of washer and pull line. Cut the torn lines so u at least have a line that is clean and mostly straight, but dont cut TOO MUCH!! just the bare edge, about 1/8 " inch. Use some needle nose pliers ,real small ones.. to pull the line from bottom of door and apply connector. Put lines back on and do faceplate and check for leaks. Good luck!!
Posted on Apr 04, 2009
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
SOURCE: KENMORE MODEL 106.55526400 SIDE BY
Hi Please check the water inlet valve, it might be frozen or blocked
with mineral deposit. Use a hair dryer to remove the blockage. Make sure the
water inlet valve's screen is not blocked. If the issue persists, then the
water inlet valve has gone bad, use a multimeter to test the water inlet
valve's continuity. Use a multimeter to test the continuity. Hope this
helps...please post back for further assistance. Daniel
Posted on Aug 08, 2011
Apr 12, 2015 | Kenmore Refrigerators
Apr 02, 2014 | Kenmore Refrigerators
Aug 28, 2013 | Kenmore Refrigerators
Mar 13, 2013 | Kenmore 53642 / 53644 Side by Side...
Oct 21, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jun 29, 2010 | Kenmore 24.5 cu. ft. Side-by-Side...
Nov 27, 2009 | Kenmore 57029 Side by Side Refrigerator
Feb 16, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Jan 03, 2009 | Kenmore 57029 Side by Side Refrigerator
Jun 28, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dec 20, 2020 | Kenmore Refrigerators
101 people viewed this question
