Question about Vizio Televison & Video
Need help with Vizio E65-E0 screen flashing on and off every 2 seconds. Picture is fine when viewable between flashes...
Between the refinery led angle above the top
Posted on Dec 15, 2019
    Top Expert:
  • Vizio Master
  • 76,204 Answers
Sounds like back-light problem. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
sounds like
6ya staff
SOURCE:
tvtek
Duke
  • 1284 Answers
SOURCE: Vizio L32 picture too dark
Bring it back as you can't get parts for Vizio.
Posted on Jun 10, 2008
Anonymous
SOURCE: Picture flashes for 1/2 second then is gone...sound continues
power supply if led ligth stays blue and then after a few minutes changes to orange is your power supply.if light color goes to a purple that is your mainboard $$$$$$$$$$$
Posted on Jan 28, 2009
Axle80
Axle80
  • 73 Answers
SOURCE: 50" Plasma Vizio P50HDTV10A - no video - just flashing B & W
Don't replace anything, Vizio has issued a lifetime warranty for this set because of this problem. No joke, call the customer service line and tell them you got the pop of death. They'll send someone out to 'repair' the set free of charge. If they can't fix it they'll give you a new one. Even if your mfg purchase warranty has expired. Call them and post the results. I've been fixing TV's longer than I care to admit and this is the first time I've actually seen a company stand behind their products like this. I bought a broken tv with the intent of fixing it and after replacing almost every board I could only manage to get the vertical racing stripe line, except mine was purple. I put it all back together and called to find out if there was a recall on this set and within 5 minutes the (Actual English speaking) gentleman told me to sit tight and he'd have a repairman come and do his thing. He did, and long story short, he couldn't fix it. Last week they delivered a new TV to replace this one. I was shocked. I think Vizio will have all my future business.
Good luck.
Posted on Mar 23, 2009
warreno3
  • 4 Answers
SOURCE: Vizio m550nv led lcd tv. Problem began a couple
I had same problem. Unplug set for 10minutes then plug it in and let it go thru it's startup routine.
Posted on Jan 27, 2011
Rocky
  • 302 Answers
SOURCE: Vizio LCD dark screen and picture is flickering flashing
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
Posted on Nov 26, 2011
Vizio (E65-E0 & #: LAUSVKAS3702629) 65 inches TV when turned on screen flickers for 3 seconds with white horizontal lines then goes black despite Vizio's trobleshoot atempt. I need to knw the part.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the sites linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/ http://homenol.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. /
Sep 18, 2018 | Vizio Televison & Video
Flashing vizio plasma tv
Open it up and locate the source of the clicking. Chances are that is the defective board in your set.
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 21, 2017 | Vizio P50HDTV10A 50 in. Plasma HDTV
Nov 25, 2011 | Vizio 42 in. LCD TV
Sound is o.k. But screen will only flash every few seconds.
The 2 long LCD inverter boards are dead.These 2 long LCD iverter boards,help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy these 2 long LCD inverter boards for the replacement.
Jul 07, 2010 | Vizio P50HDTV10A 50 in. Plasma HDTV
Flashing screen
i have Phone Nokia E65 uith flasing screen and split in haf two diferent imagine an clear .
The problem was start after i recive fhone call .
Mar 08, 2009 | Nokia e65 Cellular Phone
Nokia E65 screen it´s blinking
yes this problem is related to the flash u need to flash ur phone if that didn't help u need a flex cable replacement
flash= give it to a trusted phone repair man and tell him i want to flash my phone
flex cable = u cant take the phone apart and replace the cable that connect the keypad to the lcd/call buttons
PLz do rate this post as good as u can so we can help others.
Oct 24, 2008 | Nokia e65 Cellular Phone
Picture blinks in and out every few seconds
The lines in the picture and the blinking makes me think maybe the digital / logic board is going bad.. you will need a tech to resolve this and it will be expensive.. In time you will loss the picture altogether as the board will get worse.
Jul 06, 2008 | Vizio L32 32 in. LCD HDTV
Black screen, small portion of top of picture in view at bottom of screen
your tv has a vertical problem take it to a tech to have them look at it probably on transporting the set to your house it bump around.a look on lose solder could be the problem this could be verified by a tech.good luck.you need the repairman.
Apr 01, 2007 | Sony KP-53HS10 TV
Black screen w/small portion of top of picture showing at bottom of screen
Hello, the problem with your projection TV is in the so called bad soldering in the vertical deflection stage. Please contact a pro in order fot fix the error. If you need more assistance please advice. Arpi
Mar 18, 2007 | Sony KP-57HW40 57" Rear Projection...
Televison & Video Logo
37 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
