Question about Yamaha Audio Players & Recorders
How to change the rubber band for the drive to open the drawer on a yamaha cdc 91
    Habit-Forming:
  • 18 Answers
6ya staff
SOURCE:
Robert Johnson
  • 395 Answers
SOURCE: Yamaha CDC-705 Parts
you can get it at www.partstore.com part # VQ776900 for $1.95
Posted on Jan 07, 2008
Anonymous
SOURCE: I need a new belt for my Yamaha cdc-615. The belt
Jusy had the same problem. The player worked fine until one day I went to use it and the tray would not open. The belt had streched and was too loose. Since the player is quite old finding a replacement belt was next to impossible. So I went to the local hardware store and bought a Danco #56 rubber O ring (Stock# 35770B, 1 1/2 O.D. x 1 3/8 I.D.) I replaced the belt with the O ring and it works perfectly. The original belt is a V belt but the O ring seems just fine. Important that you do not get one any smaller because it may stress the motor drive shaft and bend it.
Posted on Dec 27, 2009
Anonymous
SOURCE: The disc tray of my Yamaha cdc-745 CD player does open properly.
It's the belt inside the machine - open tray and look in front left side and you will see it. Easy to change out with new one.
Posted on Feb 28, 2010
Anonymous
  • 141 Answers
SOURCE: need drawer belt for Yamaha cdc-805 CD changer
Any decent repair shop should have a large supply of replacement belts. The Part number isn't necessary. Just take the old one in and get a new one just 2mm smaller than the original. Some repair shops won;t sell them because they don't want you repairing your own property but a decent shop should sell you one.
Posted on Apr 07, 2010
gopakumarg43
  • 76204 Answers
SOURCE: Yamaha CDC-80 drawer won't open
Hello
There are two possiblities for this fault. The first one is, loading belt broken, or loose. The second one is, loading motor fails to rotate. it may be due to voltage related problem, that is, no voltage comes to it from the circuit board, or it has failed to rotate due to some internal fault itself.
You just open and inspect for these troubles Ok.
Posted on Nov 27, 2010
Sony cdp-ce525 drawer won't open
How old is the DVD player? I have a Yamaha 5-disk player and the rubber drive belt that wraps around the drawer motor and connected to the pulley for the drawer was stretched out and useless. Just bought a new one online and voila!
Jun 16, 2014 | Yamaha CDC-745 5-Disc CD Changer
CDC-735
Part Number VQ776900. I got it online for 99 cents but other places can be up to 7-8.00 dollars. I removed 5 screws on the sides and rear of the case. Took case off. Press the open button and help the drawer open with your hand while the motor tries to. Then remove old belt with pliers or paper clip, etc.
I did not take anything apart on the inside to replace the belt. Push the belt into the player over the larger wheel and then I pulled the belt with a paper clip over the smaller drive wheel.
Mar 17, 2012 | Yamaha CDC-755 5-Disc CD Changer
Hello
Nov 27, 2010 | Yamaha CDC-655 CD Player
I have a cdc 675 CD changer, When I close the draw it stays close about 10 seconds, the display reads "open" and it opens back up whether there are discs in it or not
It's reporting that it (correctly or incorrectly) detected that the drawer has not fully "closed", i.e., it thinks that there was a "jam" while the drawer was sliding towards the "closed" position.
This sounds (pun intended) like you need to take the unit to a qualified audio/video technician, to trouble-shoot, and maybe check the "alignment" of the drive-tray.
Sep 30, 2010 | Yamaha CDC-675 5-Disc CD Changer
Need drawer belt for Yamaha CDC-805 CD changer - the one needed that opens and closes the changer's door - not sure where to get it or the part number. I thought I ordered the right one and got the 'drive'...
Apr 07, 2010 | Yamaha CDC-745 5-Disc CD Changer
I have a Yamaha CDC-80. The CD drawer won't open and it makes a noise like it is trying to open, but is stick
Most probably, a rubber band that drives the drawer open is too too old. If you cannot find a new rubber band, a cheap and dirty solution just using a screw driver to pull out the drawer. BTW, I am having the exact problem, and I am still looking for the right rubber band. Hope it helps
Oct 26, 2009 | Yamaha Audio Players & Recorders
Note: CDC-625 unit won't open, no discs inside
Wait, wait!
I bought one of these units from a flea market for $5.00. It said the tray wouldn't open. I picked it up, and noticed the same thing you did. Humming motor, but the tray stayed put.
I opened it up to check things out, and all that was wrong was a (very) stretched out belt on the pulley that opened the tray. I replaced it with a rubber band and it has worked ever since. Once the rubber band wears out I'll replace it with a proper belt, but for now, it was a 2 minute fix that's lasted around 11 months so far. I really, really like this player, and plan to keep it working for a long time!
May 27, 2009 | Yamaha CDC-685 5-Disc CD Changer
Disc door keeps opening.
The drawer belt may also lift the laser up to meet the CD . If the belt is bad , the CD player will kick out the CD.
Change the belt.
Try studiosoundelectronics.com
or
mcmelectronics.com
Jan 11, 2009 | Yamaha CDC-585 5-Disc CD Changer
The drawer open & close function on my Yamaha DVR C300 isn't working.
could be that the rubber band is need of replacement, take it in to radioshack and they will get you the right piece, it should cost you a few dollars
Jan 01, 2008 | Televison & Video
18 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
