Question about LG Audio Players & Recorders
No sound from subwoofer lg ht554 home cinema.
Speaker itself works properly, but there's no signal on output,other chanels work properly, anyone has some idea? I've reseted it to factory deafult settings, it didn't help
    New Friend:
  • 24 Answers
Did you check all connections? All audio settings? If yes and it didn't help I think better will be call to specialist in this field. I recently bought new home cinema Ugee 1910B and it works perfect. Quality of video and sound is great.
Posted on Dec 24, 2019
    Top Expert:
  • LG Master
  • 55,370 Answers
If the subwoofer works perfectly when tested separately, something is wrong with the subwoofer output of your LG home cinema - perhaps it is intended for use with a powered sub.
Posted on Dec 12, 2019
Testimonial: "Hello Tom, thanks for that advice, but it is subwoofer with speakers sold as a set with HT and it worked for a few years"
6ya staff
SOURCE:
Anonymous
  • 138 Answers
SOURCE: JVC THM303 - No Sound
Its your wire connection problem. Plz check that all the wires are connected to specific location. If wiares are ok then it might be internal circuit error! that should be repaired at authorised service stations.
Posted on Dec 08, 2007
Anonymous
SOURCE: buzzing in speakers of cinema surround
I have the same problem, tried routing my speaker wires away from power wires and that doesn't seem to work
Posted on Jan 03, 2008
Anonymous
  • 93 Answers
SOURCE: no sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Posted on Feb 07, 2009
Anonymous
  • 7 Answers
SOURCE: no sound through my lg home cinema system when watching tiv
fiirst of all you should buy a converter..........which has a multiple use
Posted on Mar 04, 2009
Anonymous
SOURCE: Just bought LG HT554 DVD Receiver, was told it was
This one worked for my HT lg 554:
Power On
Open the tray
Push 0 four times
Push Pause button
Though, I didnt do the last step, since the code edition appear before.
Posted on Mar 22, 2010
Tip
LG LH-D6235 DVD Manual Download
Download LG LH-D6235 Home Cinema System Manual
Would you like to review the features of the LG LH-D6235 Home Cinema System?
Have you lost your LG LH-D6235 Home Cinema System Users Guide?
Would you like a digital, searchable, pdf version of the LG LH-D6235 Home Cinema System Owners Manual?
Follow this link (& click FREE) to download a pdf version of the LG LH-D6235 Home Cinema System documentation.
I hope that helps.
____________________________________________________________________
LG LH-D6235 Home Theater Region Free Fix
on Jul 14, 2010 | Televison & Video
Tip
LG LH-D6235 Manual Download
I hope that helps.
on Jul 14, 2010 | Audio Players & Recorders
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
Tip
I hope that helps.
on Jul 14, 2010 | LG LH-D6230 System
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
I have lg home speakers which is advd speaker sysem model lg ht3055u model when i do the test on the dvd they are ok when the tv is on sound only comes on the woofer and the 1 speaker is this how it...
Get a DAB (digital audio converter )from maplins ('40 quid) then connect your tv using optical or coax to your dab then use RCA cable fron dab to the analogue inputs on the LG and select 'cinema' on the equaliser to get all speakers.
Aug 27, 2010 | LG Audio Players & Recorders
How to hear sky tv's voice from home cinema system?
PUT A SET OF PHONO CABLES FROM AUDIO OUT ON SKY TO AUX INPUT ON YOUR SAMSUNG.SWITCH SYSTEM TO AUX INPUT SET SOUND 2 PROLOGIC 2,AND HEYPRESTO SURROUND SOUND I HOPE.
HOPE THIS HELPS.
CABLE GUY.
Jun 26, 2008 | Audio Players & Recorders
Getting audio from LG TV to play through Samsung Home Cinema System
May 20, 2008 | Audio Players & Recorders
115 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
PNiss
patseamur
Level 1 Expert
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
