Question about Samsung Audio Players & Recorders
Hi, I recently moved into a property where the previous owner built a Samsung PS-FC5500 surround sound system into the walls. All I am left with are the speakers and cables out. Anyone know where I could fi d a replacement control unit or whether any other would be fir for purpose? I want to connect it to a new 4K HD TV.
Posted by Hugo Pires on
1helpful
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
How do I connect a samsung c555 home cinema system to a LG 42LD450 42 inch tv so that i can get sound out the built in freeview? also cant seem to get sound out my PS3? I have connected the video output...
Use an optical cable from ps3 to surround sound and hdmi from ps3 to tv.... But I can't get my samsung surround sound to come out of the tv with built in freeview either. Just wondering if you figured it out. Cheers
Just purchased system. Our home was wired for
There is no absolute phasing for a given speaker. It's more important that they all have the same relative phasing.
Assuming the installer was consistent with his phasing of the speaker wires, you decide which one you would like to be red (positive or +) and black (negative or -). Kepp that convention throughout all of your speakers.
Wireless chanel clash
might be a fridge throwing off a mag feild
could be a wire running right ajasent to the speaker location
try moving speaker first
like take it off the wall and move it 3 feet
any change ?
ok that didnt work
now it is wireless but so is mine and i have to power the speakers y pluging them in
it could be if the speakers are powered then the adapters might be getting old and tired
if all fails try moving the speakers right next to the reciever and see if they still hum
ps just because the dont have an adapter pluged into the wall and it looks like a vac cord instead means they just put the adapter inside
and you are in for more fun then
Have sound on dvd no picture
Please check the video connections properly, if you are having any problem with the sound system you wont get even sound and hence please check the video connection wiring properly to resolve your issue.
How do I determine my tv's configuration.
You can get configuration from the link below
http://www.mediacollege.com/equipment/samsung/tv/hc/hcn529w.html
I'm installing a surround system in my basement. My question is where else can i install my center speaker? I'll be installing an electric fire insert with a large T.V. above on a 6ft stone tile wall. I'll...
Hi, you can tell your amp there is no center speaker and the sound will be diverted to the left and right or for better sound if you can get a custom install speaker built into the wall or if the tv is high up on the wall put your center in the ceiling.
hope this helps.
CABLE GUY.
3answers
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Our heater wont light
your in the wrong section this is airconditions
Surround Sound Speakers and AUX
You have the mode selector for the surround sound on the wrong switch setting. Look at the owners manual to see what setting you need for synthensized suround. Go to http://www.samsung.com if you need an owners manual. You will find it with a little bit of searching. Good Luck
Top Samsung Audio Players & Recorders Experts
 Francisco Mauricio...
Joaquim Martins
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
